#15 |
Moderator
This is a big deal. And from what I’m seeing on the HP Tuners forum, it doesn’t sound like HP Tuners is even putting any resources into the 2020+ TCMs in terms of trying to crack it.
#16 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
As you stated, there's plenty of ways around a high revving cam, most swap cams in these cars for the fuel lobe and there's no need to rev the Hell out of the engine when more power can be had with more boost. I agree that there could be SOME ET left on the table with a properly tuned trans, but its not going to be much. I'd argue that these cars not having port injection is a FAR bigger limitation than the trans tuning. |
#17 | |
Again, All I said was the 2020+ A10 can not be tuned. I never implied anything other then stating that as a difference from a 2017-2019. Then you evidently caught feelings about it since you own a 2021 and brought up Vengeance racing said "stock trans tuning is fine to 1000hp". Fine and optimal are 2 different things. I agree that most buying these cars do a few simple mods and call it good. So yeah not a big deal, but for others that want to mod heavily it's an important detail to know which is why I mentioned it. Fyi, There is a solid 2-3 tenth reduction in 1/4mi ET alone from trans tuning even on a stock car. Yep I have read the same.
#18 |
Pretty minor detail IMO, but the infotainment is updated on the 19’s & up.
2020 ZLE Roto-Fab dry
2018 Camaro 2SS 1LE - 2" TSP catless headers, Pray Ported stock IM/TB, Rotofab dry, DSX FF kit, dyno tuned by Pray. SOLD |
#19 | |
If I could start life over again, I'd probably consider a minor or even a major in psychology
#20 | |
#21 | |
#22 | |
And to be clear just because the 2020+ A10 can not be tuned doesn't mean I wouldn't buy one. There is a guy on FB that posted times of his 2020 A10 ZL1 going 9.8 @ 139 Full bolt-on with stock trans tune. Then says right at the end of his post. "Stock trans tune is holding it back". Pray Performance also had a comment on this. I'll post some screen shots below. Either way it's pretty much like this. The 2020+ A10 can not be tuned = Fact's from HPtuners X shop said A10 trans doesn't need tuning until 1000hp = Speculation provided by a C6 member that has provided no data or credible info to back that claim up.
#23 | |
But that's where I'll stop before OP comes back and cracks the whip at us for steering his thread awry.
#24 |
Petro-sexual
No Homelink starts in 2020, if I recall correctly.
I don't think you can get the optional dealer ELSD-reflash for anything after 2019 either. At least that's the last I've seen. I don't know if it matters much...
#25 |
![]() Drives: 2018 ZL1 Nightfall Grey Vert Join Date: Dec 2020
#26 | |
The infotainment theme was redesigned, too for the 3.0 version in 2019, which I don't care for much, but it is definitely different.
#27 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
I would say the biggest difference between the two would be cost since you can’t buy a new 2018 now!
#28 |
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
So im wondering Something I have a 20 ZL1 that was manufactured in Aug 2019 it that mean my TCM can't be unlocked snice its a 20?
