Old 02-24-2021, 10:59 PM   #15
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Originally Posted by kdm123 View Post
I'm wondering if disabling the TPS sensors will fix this problem of the stability control not turning off when low tire pressures are sensed. Has anyone tried this?
you can run all pressure sensors or none...
Old 02-25-2021, 12:32 AM   #16
kdm123
Drives: 2018 ZL1-1LE
Right, so with all sensors disabled, the computer will ignore tire pressures and allow me to d/c the stability control, correct?
kdm123 is offline   Reply With Quote
Old 02-25-2021, 04:00 AM   #17
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
I would think so. When I put on my Z/28 rims and rubber, for some reason the TPMS sensors would not sync up. I didn’t want them pulling the tires back off and told them to leave it alone and I would live with checking tire pressures manually. Even with no sensors reading I have been able to shut of T/C and S/C.
I’m assuming I am doing it right as both lights come on. I’ve done this several times too.
Old 02-25-2021, 09:48 AM   #18
az4783054
Drives: SWXXZL1
it could be a california thing
"Joe" does a hilarious impression of a slinky toy on stairs.
az4783054 is offline   Reply With Quote
Old 02-25-2021, 10:05 AM   #19
LJS-ZLE
LJS-ZLE's Avatar
Drives: 2019 Camaro ZL1 1LE
I have a 2019 ZLE and had trouble deactivating stability control when trying to do an autocross event. I was eventually able to completely deactivate it and my memory is that I first went into race mode and then pressed the traction control button for 5-10 seconds which then shut everything off. Good luck!
LJS-ZLE is offline   Reply With Quote
Old 02-25-2021, 12:26 PM   #20
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
This seems to work effectively on my car. In fact, if memory serves, it seems to just override ESC until you turn it back on. I think it even allows you to switch between modes - even Touring.
And it wouldn't be a surprise if it was a CA-thing, HA.
'20 ZL1 Black "Fury"
