Old 08-19-2020, 03:58 PM   #15
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Originally Posted by PROMETHEUS View Post
Or just get an aftermarket SC reservoir.....makes life so much simpler!
+1
ZX-10R is offline   Reply With Quote
Old 08-19-2020, 04:05 PM   #16
ht600
ht600's Avatar
Drives: 2019 Camaro ZL1
Originally Posted by DFW_Muscle View Post
That will not work.
It's not a matter of simply getting a small enough tube in the port to fill. There is a checkvalve that needs to be depressed. Guys that use the upside down bottle with a hose use a thin screwdriver to depress the valve. Your suction gun won't provide a way to depress the valve.
Buy the DMS tool, or buy an aftermarket expansion tank. Or, buy an expansion tank and replumb the system like I did (DMS also makes adapters to convert the male push fittings on the blower to -12an fittings).
Not using the suction gun to fill anything just to remove excess fluid from bottle after using the tool.
The tool depresses the check valve.
From Dedicated Motorsports
LT4 SC Coolant Filler Adapter Tool
Lets face it, the coolant filling system found on the LT4 supercharged Camaro ZL1 and CTS-V can be a real pain in the butt to fill. Over the years we've tried a number of different solutions but none of them did the job without some pitfalls. DMS recently designed a 3D printed adapter that makes a water tight seal on the filler fitting while depressing the check valve allowing the use of a very common soda or water bottle to act as a "funnel". The threads are the same as many drink bottles like Coke, Dr. Pepper, Mountain Dew, Smart Water and many more. This makes the tool small and easy to keep in the car for those unexpected cooling system filling needs.
Fits:
2016-2019 CTS-V
2017-2019 Camaro ZL1
2016-2019 ATS-V
List Price: $14.99
ht600 is offline   Reply With Quote
Old 08-19-2020, 07:53 PM   #17
Jerry300zx
Drives: 2018 Camaro ZL1
How would one know the supercharger coolant has air in it other than power loss? My car is weird. Some days it's fast as hell, others it feels sluggish. Is this something I can ask the dealer to do?
Jerry300zx is offline   Reply With Quote
Old 08-19-2020, 08:41 PM   #18
Vigilante375
No way to really tell other than what you described. The dealer can do it but it's cheaper and faster to do the same thing the OP is doing or just buy a reservoir and never deal with this issue again.
Old 08-19-2020, 08:52 PM   #19
20Bluezl1
Originally Posted by ZX-10R View Post
+1
What coolant reservoir are guys running?
Does it have to be mounted higher the the lid?
Old 08-19-2020, 09:20 PM   #20
ZX-10R
ZX-10R's Avatar
I have the ADM which is mounted higher but doesn't absolutely need to be, the Cordes will also work. I have an Elite catch can mounted in front so ADM made sense
Old 08-20-2020, 12:00 PM   #21
cirpower
Drives: Camaro ZL1
I had the ADM, but then got rid of it and went with Cordes. I did not like the ADM for the mounting (kept coming loose, is not strong enough in my view) and the position (lots of heat above the headers).
cirpower is offline   Reply With Quote
Old 08-20-2020, 12:28 PM   #22
ZX-10R
ZX-10R's Avatar
What was coming loose? The nut attaching to the firewall? Just go nyloc, problem solved. The weight is next to nothing.
As far as heat, the reservoir barely gets hot. Even after a hard run on a summer night I can put my hand on it - not worried. Having an oil catch can there is also a risk
Old 08-20-2020, 12:48 PM   #23
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
https://www.camaro6.com/forums/showthread.php?t=503216
Andy told me what gates hoses to source all listed on this thread.
https://www.camaro6.com/forums/showt...=544573&page=3
scroll down to post 39... for list of hoses, T, fittings, reservoir 51-7100 and bracket
Old 08-20-2020, 06:42 PM   #24
20Bluezl1
So I was looking to see if there was an aluminum reservoir that can be installed over the headers snice i will be adding an Elite ultra can in the front. Not to worried about the heat over the headers as im getting ARH headers and sending them to Swaintech.
Has anyone tried the tank in the link below?
https://www.tickperformance.com/big-...art-b3r-zl1-b/
Old 08-21-2020, 08:27 AM   #25
ZX-10R
ZX-10R's Avatar
Had not seen that one before but looks great
Old 08-21-2020, 03:01 PM   #26
puppykat33
puppykat33's Avatar
Drives: Black 2019 ZL1 M6,
300 dollars vs what 40 bucks sounds like a good option. i mean who is continuously pulling off their supercharger where it needs to be bled that much. For a use every once in a while type deal i think this is prob a better idea.. just my opinion
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
puppykat33 is offline   Reply With Quote
Old 08-21-2020, 03:03 PM   #27
ht600
ht600's Avatar
Plus no problems with the dealer if warranty work is needed.
