Old 08-12-2020, 06:33 PM   #15
travislambert
Drives: '17 ZL1
Originally Posted by HavocZL1 View Post
Cool - what was it that you used? Tremec HP? I feel like that's the safest way to go.
Yeah. Tremec HP-MTF.
https://www.tremec-store.com/collect...smission-fluid
travislambert is offline   Reply With Quote
Old 08-12-2020, 06:40 PM   #16
Flowtie1
Drives: 2017 ZL1
What does it say on the tranny ? I bet DexronIII
2017 ZL1 M6 Silver Ice Metallic
Flowtie1 is offline   Reply With Quote
Old 08-12-2020, 11:34 PM   #17
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
What are your thoughts on the Royal Purple Synchromax? So bizarre that you can use ATF in a manual...
It's weird but that's what it's designed to take.
https://www.tremec.com/anexos/TREMEC_TR-6060_1017.pdf
And heh, in some cars, ATF also served as the power steering fluid.
As for Royal Purple, personally I don't like it much just because back in my RX-8 days, I have heard cases of synchro failures after people put Royal Purple fluid in. No idea about how much the TR-6060 likes it, but again, make sure it meets Dexron III standard.
Originally Posted by travislambert View Post
That was my logic. Other fluids may work great, but I figured there is always a chance of an incompatibility with a chemical and a material inside the transmission causing premature wear. With OEM fluid and fluid direct from the transmission manufacturer I feel like that risk is minimized.
Since the OEM fluid was falling a little short, the natural choice for me was to try the Tremec fluid. So far, I couldn't be happier.
Makes sense, but I have no idea where to get the TREMEC stuff in Canada... Amsoil stuff is available locally. No expensive shipping to worry about.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 08-13-2020, 08:50 PM   #18
69pro-touring
69pro-touring's Avatar
Drives: 2017 ZL1 6MT
I swapped mine out to Redline D4 ATF on forum recommendation (was also considering RP synchromax) after having some issues shifting into and out of reverse and have not had issues. A few thousand miles later and a couple autox and track days, have also noticed smoother shifts overall compared to OEM fluid.
69pro-touring is offline   Reply With Quote
Old 08-13-2020, 09:53 PM   #19
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Factory juice works pretty good so far across a very wide temperature range.
ing for grip.
http://www.motorsportsne.com/
Old 08-14-2020, 06:25 AM   #20
Redlinez
Shifts under load
Redlinez's Avatar
I ran the Redline ATF in my last SS and honestly couldn't tell any difference.
22 Suzuki GSX-S 1000GT blue
Old 08-14-2020, 09:31 AM   #21
m3bs
m3bs's Avatar
Drives: '19 ZLE, S54 E36M3
My 2019 owners manual says to use GM part # 88861037, which is Dexron VI, not Dexron III. I had some issues with balky shifting at high temps (>225) on track recently with the OE fluid. I'm wondering if I should try a slightly heavier oil. It's primarily a track car, so cold conditions aren't a big concern. Supposedly the Dexron VI starts out a little thinner than III, but they both shear down to the same viscosity.
m3bs is offline   Reply With Quote
Old 08-14-2020, 12:46 PM   #22
Russell James
Russell James's Avatar
Drives: '15 SS 1LE, '69 Z28 drag car
I've put RP Synchromax in every Tremec 6spd car I've owned. Always works great. The RP Max Gear works great in the rear diff as well.
Russell James is offline   Reply With Quote
Old 08-14-2020, 09:10 PM   #23
travislambert
Drives: '17 ZL1
The Tremec fluid will solve that problem. You won't be disappointed, and you'll have some peace of mind knowing the fluid is engineered by the same folks who engineered our transmission.
Old 08-15-2020, 12:50 AM   #24
waterman
waterman's Avatar
Drives: Grandad's C2 L89
+1.
FWIW, for me the throws (up and down) are smooth as silk throughout the entire rev range. A noticable improvement over OEM gear oil. More importantly, I'm seeing/logging lower gear temps under heavy load. Better performance and potential longevity.
IMHO, I don't see a better product available for 6060... Tremec gear matched to a gear oil specifically developed/engineered by the same company that developed/engineered the transmission.
Win/win for me.
2018 ZL1 1LE sw/PDR
Old 08-15-2020, 09:51 AM   #25
Redlinez
Shifts under load
Redlinez's Avatar
Tremec oil it is, thanks! Pretty funny how Tremec is cheaper than Summit.
Old 08-15-2020, 11:23 AM   #26
HavocZL1
HavocZL1's Avatar
Drives: 2020 Camaro ZL1
So what are the differences bewteen Dexron IIIG, IIIH etc?? Anyone?
HavocZL1 is offline   Reply With Quote
Old 08-15-2020, 11:50 AM   #27
m3bs
m3bs's Avatar
Just placed my order with Tremec.
Old 08-15-2020, 12:00 PM   #28
HavocZL1
HavocZL1's Avatar
Would love to know what you think after driving a few hundred miles!
