Old 07-06-2020, 09:06 AM   #15
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Originally Posted by Stephen12ZL1 View Post
very good advice listed above...likely the intercooler circuit has an air pocket...ECM dials back timing in this instance due to high IAT2 temps.
Does the ECM control off of IAT2 or MAT? I remember reading that it controls off of MAT.
I also need to do some logs on my car because it definitely gets slower during sessions above 80 degrees. Good thing it's supposed to be 94 at Pitt Race Wednesday for TNiA!
Old 07-14-2020, 06:40 PM   #16
GunMetalGrey
GunMetalGrey's Avatar
Drives: 2018 ZL1 (SOLD) 992 GT3 (current)
UPDATE
So my mechanic pressure tested the intercooler system and could not find any leaks of any kind, however they said that the system was low on coolant... Obviously i’d like to know how the system got low on coolant and I can’t imagine it wasn’t the leak that I saw That now seemingly cannot be reproduced. The only thing I can think of now is to drive the car like I normally do and monitor and observe it and see if it reoccurs
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 07-14-2020, 10:12 PM   #17
TrackClub
TrackClub's Avatar
Originally Posted by GunMetalGrey View Post
UPDATE
Thanks for the update! Usually, leaks dont just disappear, unless there was an extraordinary pressure event of sorts perhaps. Good idea to check motor compartment and under the car for any leaks after each and evey session regardless of prior leaks or not. Just a good protocol for us track rats. You should know in short order if that leak comes back or not. Cheers!
Old 07-15-2020, 05:16 PM   #18
GunMetalGrey
I sure hope I know soon! This seems weird...
The good news is that the cars seems to have full power back from what I can tell, I drove the car for more than an hour and floored it a few times, so if my senses are correct, the power is back at least for now.
Old 07-15-2020, 09:32 PM   #19
TrackClub
TrackClub's Avatar
Fingers crossed! Time for a new PB
Old 07-17-2020, 11:14 PM   #20
GunMetalGrey
Yeah by more than 2 seconds from last track day!
All controls off and left foot braking along with SC3R’s have cut more than 2.5 seconds off my best lap time from last year.
No Intercooler leaks at the track... the mystery continues...
Old 07-19-2020, 01:17 PM   #21
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
I've had an internal intercooler leak - into the intake tract. There are 4 o-rings that seal the cooling fluid from the pressurized intake. A possibility...
Tim M is offline   Reply With Quote
Old 07-19-2020, 03:09 PM   #22
TrackClub
TrackClub's Avatar
Dont forget to give the driver some credit as well, eh?
Congrats!
I'd also check the o rings per the post above. Just to eliminate it as a possible cause.
Old 07-19-2020, 05:08 PM   #23
GunMetalGrey
Inter-cooler leak mystery
Thanks, I'll tell my mechanic about this and see if he has already checked this
Old 07-19-2020, 05:10 PM   #24
GunMetalGrey
Congrats!
Thanks, let's hope so!
Old 07-19-2020, 10:42 PM   #25
Tim M
Tim M's Avatar
Few images:
Old 07-19-2020, 11:31 PM   #26
GunMetalGrey
Few images:
Thanks!
coolant, heat soak, intercooler, power, pressure
