Old 04-26-2026, 11:53 AM   #15
Texan4iu
BLEW BIU
Texan4iu's Avatar
Drives: 2018 2SS 1LE Hyper Blue
ARP extended studs as I run spacers with my track wheels.
Texan4iu is offline   Reply With Quote
Old 04-26-2026, 11:56 AM   #16
LIS
LIS's Avatar
Drives: '23 2SS1LE
I do the same up front. Are you using the extended studs in the rear?
-Larry
LIS is offline   Reply With Quote
Old 04-26-2026, 11:58 AM   #17
Texan4iu
BLEW BIU
Texan4iu's Avatar
Yes. Figured just in case I needed the length for some reason. ��
Old 04-26-2026, 12:08 PM   #18
LIS
LIS's Avatar
Drives: '23 2SS1LE
Good idea, thanks!
Old 04-26-2026, 12:49 PM   #19
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Originally Posted by LIS View Post
Old thread I know, but I just broke a rear stud at the track. For those who have replaced them, are you sticking with stock parts, or is there something better?
TIA,
Larry
Not really on the camaro platform but automotive in general, ive replaced thousands of wheel studs and the stock replacement is usually enough. If you get different temper metals then it's going to change how your torque spec is applying pressure. Most all bolts will have a life expectancy when it comes to loosening and tightening. Comparing your car that you swap wheels every time you get ready to race and get finished racing vs your daily driver that the wheels come off only when services are needed. Your racecar is going to go through studs faster and it's going to be "within limits".
So i would suggest just stock replacements and factor it in your budgeting and service schedule. Or just keep some on hand.
Old 04-26-2026, 12:57 PM   #20
LIS
LIS's Avatar
Drives: '23 2SS1LE
This is fair. The issue I have is that the effort to replace the rear studs is non-trivial, and not something I want to do trackside. If there are better parts that'll be less likely to fail, I'm in.
Thanks,
Larry
