Old 05-12-2020, 05:21 PM   #15
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
At home I have a Bendpack LR-60 low rise scissor lift and use 1+" thick Bendpack lift pads under each ZL1 lift pad, and the rockers clear the Bendpack ramps by at least 1/2".
When jacking the car at the track using my portable jack, I use the ZL1-AO pinch weld mag jack puck--the integrated hockey puck provides the needed clearance from the jack surface. I rest the car on jack stands under the attached lift pads, place/center them carefully under the lift pads and use good thick rubber top covers on jack stands or they could slip.
I recommend ZL1-AO lift pads AND a portable pinch weld jack puck to all ZL1 owners.
SFV1LE is offline   Reply With Quote
Old 05-12-2020, 06:48 PM   #16
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
Originally Posted by Rodan View Post
I use the ZL1 addons lift pads for my jack stands, located as far forward and rearward as possible on the pinch welds. I agree they would be much more useful if they were a bit longer.
For jacking, I have several of the magnetic pinch weld pucks, similar to this:
I use a hockey puck under that as a spacer for my jacks. When I'm putting the car on stands, I lift the front first, with a jack on each side lifting together, and then lift the rear with a jack under the diff crossmember.
I've used the 'pucks' on each side for swapping tires at the track one side at a time. No issues with rocker panel or pinch weld damage.
I did forget to pull one of the pucks off once... three days later it was still hanging there.
Have you ever tried to lift the front of the car one side at a time and put it on a jack stand and then do the other side front and put it on a stand and then lift the rear together? I have the lift pads 4 jack stands and 1 floor jack. I haven’t had all 4 wheels off the ground at one time yet and I’m ready to change my diff fluid.
2004YZFR1 is offline   Reply With Quote
Old 05-12-2020, 08:58 PM   #17
Rodan
Drives: 2018 ZL1 coupe
You can do it that way, but you'll have to lift side to side in stages. I would not try to lift it to the full jackstand height one side at a time.
Rodan is offline   Reply With Quote
Old 05-12-2020, 09:04 PM   #18
Alain
Alain's Avatar
This is VERY good advice !!!
2018 ZL1 1LE/Red hot
Old 05-13-2020, 08:18 AM   #19
2004YZFR1
Old 05-13-2020, 11:02 AM   #20
BlueinTN
Drives: gas powered
Cool thats the lift I have I was wondering how well it lifts our car. What did you do to get the car over it if you dont mind me asking.
2018 ZL1 ZLE
Oldblueaccord <<< MY YOUTUBE PAGE!
BlueinTN is offline   Reply With Quote
Old 05-13-2020, 12:36 PM   #21
SFV1LE
I added a set of four 2 ft long, 1 ft wide, 1 inch thick plywood boards on each side front and rear, that's all you need to clear ramps on my ZLE and have room to slide in the thick rubber Bendpack lift pads that came with the LR-60P, under each ZL1-AO pinch weld lift pad.
Tires sit firmly on each board when parked centered over lift, they shift after parking a few times so I get out of car and line them up occasionally prior to parking.
I use one of these mounted on front wall with 2 laser dots aligned on top edges of L/R dash gauge cluster to line up parking position and distance on lift. Works great.
https://www.amazon.com/dp/B0835R1QWZ...dDbGljaz10cnVl
Old 05-14-2020, 06:22 AM   #22
Chris 2018 ZL1 A10
Drives: Chevy Camaro ZL1
Originally Posted by neb View Post
ok im not worried about the jack or lift points. more worried about the fact i have seen 4 or 5 seperate posts on this and other sites refer to seeing wrinkles or dimples in quarter panels from the strain of lifting the car by that rear most front point. Also some talk of how those pinch welds are for lifting straight up not putting side angle on. Seems a lot of guys have trouble with the zl1addons pads sliding off stuff and causing rocker damage from the jack or stand too?
Hi Neb,
I just received 4 ZL1 AddOns 3” MagPads. Unfortunately, all the pucks slide off the pad when handheld at the slightest angle, no way I’m going to trust my car being lifted like this. I’ve already expressed my concerns and am waiting to hear back from them. As for lifting the car using the aft-most forward lift points with the QuickJack, some seem to be ok with it but I would not. Looks like too much front overhang and the fact that some are complaining about wrinkles is enough to cause me to stop and reconsider.
QuickJack does make a model (BL-6000) that has an additional 10” of span which may be enough to utilize the rear and forward-most lifting points. Unfortunately, that model is also their heaviest at something like 110lbs per jack.
A more serious concern for me is the fact that some have received their QuickJacks in boxes that have been subjected to significant abuse during shipping. This raises a serious questions in my mind as to wether or not structural damage to the jack has occurred. If I decide to buy one, I’d be willing to pay extra to have it shipped as palletized freight.
Chris
Chris 2018 ZL1 A10 is offline   Reply With Quote
Old 05-14-2020, 12:31 PM   #23
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
My question is, if the aft of the 2 forward lift points is unacceptable to use, why did they put them there in the first place? Even using jack stands you either need to jack on that aft/fwd lift point or you're going to put the jack stand on it...
Old 05-14-2020, 12:45 PM   #24
Chris 2018 ZL1 A10
Great question. My guess would be that the aft/fwd point may be intended for lifting one side only while the 2 opposite tires create a tripod effect.
Just a guess...
Chris
Old 05-14-2020, 06:20 PM   #25
69pro-touring
69pro-touring's Avatar
Drives: 2017 ZL1 6MT
This is all news to me. I've always just used a HF low-profile jack and an amazon magnetic pinch weld puck to jack one side at a time. Even if I place it at the front most jack point it still lifts the rear up before you could get a jack under it. Never had any issues before, now I'm going to be worrying every time I swap wheels.
69pro-touring is offline   Reply With Quote
Old 05-14-2020, 07:01 PM   #26
Alain
Alain's Avatar
Originally Posted by Chris 2018 ZL1 A10 View Post
Hi Neb,
Chris
The boxes on my shipment when I bought mine were pretty damaged also.
The quick Jack frames themselves would take a hell of a lot of abuse to get damaged. I think you could drop them from the roof of your house and they'll probably be fine.
It's the power unit/pump you have to worry about. That thing comes in a different box from the actual frames. I made sure that box was not beat up when I got mine.
I wouldn't worry too much about the boxes the frames are shipped in being damaged.
Just a guess...
Chris
This is a great guess and it's mine as well.
I think that middle pinch weld is there for quick tire changes at the track. You lift the front and rear wheels at the same time, take the wheels off, slap the new ones on and put the car down.
I don't think the car is meant to be completely suspended in the air using the middle jacking points.
Old 05-18-2020, 05:37 PM   #27
Techdude99
Techdude99's Avatar
Drives: 2019 Chevy Camaro ZL1 1LE
My Quickjack arrived with beat to crap boxes, but they ended up mostly fine. Quickjack sent out a replacement part ASAP. Be sure to tighten the valve stems. All were loose.
Techdude99 is offline   Reply With Quote
Old 05-19-2020, 07:20 AM   #28
harner
harner's Avatar
Drives: 2018 ZL1 A10
I have a lot of friends who are pro detailers and have a quickjack in their shop that is used daily. They work fine. Anyone complaining of instability or something likely did not set them up properly.
I highly recommend ZL1Addons' lift pads. I have had my car in the air a few times and it really makes me uncomfortable, but jacking up a car by its pinch welds alone really hurts my brain. My car was also on a 2 post lift last year. The arms were very close to touching the rockers, but nothing to really sweat over.
SOLD! 9/1/2020 2018 ZL1 A10 Hyper Blue - Rotofab CAI, Gibson catback
@SurefireDetail
OEM ZLE tails/third brake light, Gen5DIY reverse LEDs, front Amber LEDs, SMG laser LED side markers, SMG smoked reflectors
1994 Trans Am LM7/CPT 4L60E/9"
1987 IROC
2006 Silverado
harner is offline   Reply With Quote
