Old 04-22-2020, 07:57 PM   #15
Trak-Toy
Trak-Toy's Avatar
Drives: 2023 SS 1LE
Yep, it’s the battery tender. I have one with mine. And... never use it so you’re not missing anything important there.
Mine is an SS 1LE package so there aren’t any front rotor dust shields or auxiliary brake ducting with this package because it has the ball joint heat shield on it and ducting from the factory. (the regular SS package has these in that storage spot for track use only).
There should be a tow hook, (2) orange, front spring blocks (Used only when transporting on the truck), a tire inflation kit, and fuel filler funnel.
Trak-Toy is offline   Reply With Quote
Old 04-23-2020, 12:32 AM   #16
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
the orange spring spacers only come on 1le and zl1.
the only thing they all come with are a fuel funnel and a tow hook. the inflater only comes on non run flat cars and the charger is a option.
Old 04-23-2020, 12:36 AM   #17
~Jb
~Jb's Avatar
Drives: 2018 ZLE
The foam insert fits other GM products. The only items you should have are:
-Tire inflation kit.
-Tow hook.
-Capless gas funnel.
-(the velcro strap area is for a jack that the Camaro never got)
2018 ZL1 1LE (CARBON/PDR/NAV)
~Jb is offline   Reply With Quote
Old 04-23-2020, 02:07 AM   #18
jrizzle
jrizzle's Avatar
Drives: None
I see tire inflator on my build sheet so I knew that was missing.
As far as the tow hook goes, should I pick one up? I know it's used for towing, of course, but all towing? Like if I broke down and had to be towed the tow truck driver would need it to tow my car? Are they vehicle specific, or universal?
jrizzle is offline   Reply With Quote
Old 04-23-2020, 02:22 AM   #19
JCunningham
Drives: 2017 2SS M6
yes if your car wont move on its own power the tow truck driver would need that tow hook. there is no place on the 6th gen camaro to hook the winch too. there is no place to put the ratchet straps on the car so they can legally flatbed it either. They have to have tire straps that wrap around the tires to flatbed it.
Old 04-23-2020, 02:37 AM   #20
Nate_K1500
Drives: 2016 Camaro SS
I have the tow hook, fuel spout, brake ducting, battery tender, car cover... Just no inflator (have run flats)
Nate_K1500 is offline   Reply With Quote
Old 04-24-2020, 04:50 PM   #21
cdrptrks
cdrptrks's Avatar
Is there a part number for the gas funnel? TIL that it has been missing from my trunk since I bought the car.
Old 04-24-2020, 06:09 PM   #22
s346k
s346k's Avatar
Drives: like an old lady
a battery tender offered with a package including a heated steering wheel and heated seats. sounds about right.
i want every option. all of them.
Old 04-24-2020, 09:17 PM   #23
Racerman27410
Racerman27410's Avatar
Drives: 2016 SS 2SS
I got heated steering wheel and heated seats...... no battery tender. no inflation pkg since the car had run flats.
Racerman27410 is offline   Reply With Quote
Old 04-24-2020, 11:43 PM   #24
JCunningham
Drives: 2017 2SS M6
junk yards should have boxes of them. GM has been using it since 2017 in all vehicles i believe. i know all camaros and silverado use it. if you bought the car from a GM dealer maybe they will give you one for free.
Old 04-25-2020, 12:23 AM   #25
Zr8000
Drives: Chevy Camaro
The gas filler was in the glove box on mine. Everything else went in trunk went in the trash can
Zr8000 is offline   Reply With Quote
Old 04-25-2020, 07:56 AM   #26
wnta1ss
Drives: 2017 Camaro 1SS
Don't know about ordering the factory one. But, have seen a yellow one (capless funnel) in an auto parts store. The opening is longer so it does not look exactly like the factory one, but it does work.
Old 04-25-2020, 05:26 PM   #27
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Trunk Contents
Here's a link to some good info that was done by rlarsen462
https://www.camaro6.com/forums/showthread.php?t=551876
the funnel is 22819597
tow hook is 22873449
