Old 03-19-2020, 10:10 AM   #15
harner
harner's Avatar
Drives: 2018 ZL1 A10
I needed more volume with my car and ended up searching for an affordable system that few had. Every seems to have Corsa, Borla, AWE, etc - and for good reason. I went with Gibson and while I'm in love with the sound and it's definitely different, the fitment and quality (specifically the tips) are trash. I'll be putting different tips on it, but ultimately had to cut and weld some of the pipes to fit. It was a full catback that did a secondary cat delete.
Moral of the story - if you decide to upgrade, go with a quality system that has countless reviews. I'll never make that mistake again.
SOLD! 9/1/2020 2018 ZL1 A10 Hyper Blue - Rotofab CAI, Gibson catback
@SurefireDetail
OEM ZLE tails/third brake light, Gen5DIY reverse LEDs, front Amber LEDs, SMG laser LED side markers, SMG smoked reflectors
1994 Trans Am LM7/CPT 4L60E/9"
1987 IROC
2006 Silverado
harner is offline   Reply With Quote
Old 03-19-2020, 10:18 AM   #16
keystonemedical
keystonemedical's Avatar
Drives: 2019 ZL1 / LE , 2014 CTS V
Agreed.....
keystonemedical is offline   Reply With Quote
Old 03-19-2020, 10:19 AM   #17
keystonemedical
Originally Posted by PROMETHEUS View Post
AWE Track Edition Axle Back with Performance Link Pipes. Sound is amazing and at WOT, what a rush. However, a lot of drone and if you use tracks with noise restriction, I suspect you would have a problem.
Do you have a clip of this by chance ?
Old 03-19-2020, 10:36 AM   #18
PROMETHEUS
PROMETHEUS's Avatar
No, I don't. But if you go to the 9.17 mark of this video. This is woman driver, who originally had the AWE Track with the secondary cats, which means without the Performance Link Pipes on her 19 ZL1 and then she added the PLP. This portion of the review gives you a great comparison between the two.
And her comments about the exhaust after is spot on! It is load and obnoxious! But if you are looking for that, this is the exhaust. They also make a touring model which is quieter.
Install with the PLP is straight forward, no cutting or welding. Remove the stock and install the AWE, it takes about two hours. Recommend two people, make it much easier. Also if you don't have one, get a exhaust hanger removal tool, it makes it so much easier to remove the OEM at the hangers. They are about $10 at any local auto supply.
Old 03-19-2020, 11:04 AM   #19
CruisintheCountryLife
CruisintheCountryLife's Avatar
Drives: 2019 Chevrolet Camaro ZL1 1LE
Thanks for the info!!
Check out my YouTube to see the ZL1 shenanigans!
https://www.youtube.com/channel/UCkm...3OKTzDGIAkqYxQ
CruisintheCountryLife is offline   Reply With Quote
Old 03-19-2020, 11:25 AM   #20
Thank you!! Do you have any issues with LTH? Ive always heard the old hot rod guys talk about probs with headers leaking, melting wires, etc. Do you also recommend removal all cats for that??
Originally Posted by Juiced1 View Post
We usually recommend customers go with long tubes and the factory NPP. It's generally perfect volume wise and having the NPP makes it easy to live with. For some who wants it louder you can always ditch the NPP from there. The AWE, Stainless Works, Flowmaster, Borla and Corsa have been the most popular sellers. I don't think you can pick something that won't sound amazing.
Old 03-19-2020, 11:43 AM   #21
ssrallyred
ssrallyred's Avatar
Drives: 2017 Summit White ZL1 M6
Originally Posted by Markoz28 View Post
If you are never going to tune it, and I mean never. Like not even maybe down the road. I would go with Corsa Extreme. It’s amazing! Tough and a good clean sound.
If going to tune it. Just stick with factory and add Headers with no cats. Should be plenty loud.
This
Roto Fab/ Kook's LT's,ported blower,removed lid baffle/ 103mm TB' lower pulley and tune.
651/660.
ssrallyred is offline   Reply With Quote
Old 03-19-2020, 11:48 AM   #22
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
I agree with Markoz28 completely.
The top recommendations are Corsa Xtreme+ cat-back/Xtreme cat-back or AWE Touring with PLPs with your choice on resonated or not. Both Corsa and AWE options have a full X-Pipe that removes the secondary cats and clamps on at the primaries.
You probably saw my thread, I have the Borla X 60606 with the Corsa Xtreme axle back, and as you said the 60606 is no longer manufactured. If I do it again, I would go with the complete Corsa cat-back system without a doubt but it wasn't offered at the time I did mine.
Old 03-19-2020, 12:50 PM   #23
Mark R
Drives: 2018 ZL-1
I have the Borla S type, which retains the NPP. Also got CF tips. I gives a really nice bark on start up, and a great sound, with no drone. I'm very happy with it.
Old 03-19-2020, 04:53 PM   #24
Zigg L1
Zigg L1's Avatar
Drives: 2018 ZL1 Garnet Red Tintcoat A10
Mark I was on the fence with the Carbo fiber tips but ended up with the standard tips for the Stype catback. How are those carbon fiber tips holding up? And how are they to clean?
Zigg L1 is offline   Reply With Quote
Old 03-19-2020, 05:01 PM   #25
Mark R
Drives: 2018 ZL-1
They are holding up great. The gas actually passes through an inner pipe. The cf is held away from the heat by mounts that keep them about a half inch from the inner pipe. They barely get warm. Easy to clean.
Old 03-19-2020, 10:34 PM   #26
jvandy50
Drives: 18 ZL1-1LE, 10 JKU
If i wanted a system with no drone I’d go corsa catback, but like others said, if you EVER plan on headers I’d pick something quieter.
I love stainless works stuff and have their catback, but I’m not going to lie...there is some minimal drone. It doesn’t bother me, but that is a no-no criteria for many. I’m wanting to add the CSP headers to mine, don’t even use my NPP option.
I do like how AWE sends the tips separate, my first SW catback came in all bashed to shit with the tips not protected enough.
jvandy50 is offline   Reply With Quote
Old 03-19-2020, 10:45 PM   #27
I'm a little Leary of headers just from what I've heard but I'm thinking of doing some power upgrades in the future at some point. So maybe I'll have to do that anyway...
