Old 03-19-2020, 12:19 PM   #15
ICTsccaCamaro
Drives: 2018 ZL1 1LE
I'm running a drop in GREEN filter and I guess I will be ripping out the air blocker tonight also.
ICTsccaCamaro is offline   Reply With Quote
Old 03-19-2020, 12:20 PM   #16
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I might try that mod FoundNemo!
Old 03-19-2020, 02:46 PM   #17
FoundNemo
Drives: 2019 ZL1
Cheers sir. Easily reversible if you dont break the tabs.
FoundNemo is offline   Reply With Quote
Old 03-19-2020, 05:21 PM   #18
Originally Posted by zx9rmal View Post
I'm proficient mechanically but not too motivated to work on my car at age 72. How difficult is the install?
Also, oiled or dry? Why do you offer both and what's recommended for a street only car?
Thanks.
Installing the Roto-Fab is easy, won't stress you out at all. I'm running a dry filter myself, but don't think there is a tangible difference in power or sound (had a wet filter before the current one).
Old 03-19-2020, 05:32 PM   #19
LT4Greg
LT4Greg's Avatar
Mal, the Cold Air Inductions CAI for the ZL1 might be an alternative for you. It is made of carbon fiber and a closed airbox and is a very easy install. It is pricey though even through Summit Racing at over $700.00.
Old 04-06-2020, 09:27 PM   #20
CDFF
Originally Posted by FoundNemo View Post
To pull the blocking plate, remove the upper radiator shroud (careful its sharp) and the annoying to get to hood latch, let it dangle. You can reach down and pull the pry pins out to remove the black plastic piece. Then reinstall the rest. Not super hard, just an annoying job.
OK with some extra time on my hands this Sunday, I decided to give this a try.
Wish I would have re-read this post first as I tried to remover the shroud without removing the hood latch. Anyway try to expand on what FoundNemo said.
Step 1) Remove hood latch and let hang (2 arrows). I used a 13MM ratcheting wrench and it worked well.
Step 2) Remove the circled 10mm bolts, torx bolts, and plastic clips.
Step 3) Remove shroud. It comes off pretty easy with a little bit of lifting on the front bumper.
Step 4) Remove 3 plastic clips that hold the plastic ‘blocker’ in place.
This was the most annoying part of the whole thing. After using every pry tool and flat head I had I removed the top clip and middle right clip, but it seemed to take forever. After messing around with the bottom clip for too long, I just stuck some big scissors down there and cut it.
Here are some pictures that hopefully make this make more sense.
CDFF is offline   Reply With Quote
Old 04-06-2020, 09:32 PM   #21
CDFF
On another note, its kinda surprising how bottled up the intake is and how little ‘fresh air’ it seems to get.
For comparison, here is a picture of the air filter on one of my other cars taken from just kneeling down and looking through the grill.
Old 04-07-2020, 07:15 AM   #22
Checkmate1
Drives: Garnet Red / ZL1 1LE
Originally Posted by kwav8r View Post
Green filter and a ported TB. Combined they cost less than a CAI and are a better up front mod IMHO.
100%. This is what I have and it is absolutely perfect.
No need for the general aftermarket or Rotofab nonsense as it just lends to more whine. HP gains are usually best case scenarios is a closed / cool environment.
#SAVETHEMANUALS
Checkmate1 is offline   Reply With Quote
Old 04-07-2020, 08:36 AM   #23
LT4Greg
LT4Greg's Avatar
CDFF, did this mod seem to help increase hp? Thanks for the pics and descriptions and is it worth the time and effort in your opinion to do it? I’m contemplating doing it and just wondering!
Old 04-07-2020, 10:00 AM   #24
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
it is a "why not" kind of mod...can't hurt and it might help.
Old 04-07-2020, 10:17 AM   #25
CDFF
I haven’t drove it yet as It’s been raining here. I hope to take it out this weekend though!
Old 04-07-2020, 10:25 AM   #26
CDFF
I agree. After seeing how indirect the air flow situation is on these cars, I would imagine removing the blocker will let the car make full power more of the time.
The path of air from outside the car into the filter is really small and definitely not ‘smooth’
Old 04-07-2020, 10:46 AM   #27
FoundNemo
Drives: 2019 ZL1
In my experience, the car definitely seemed to get into boost notably quicker, meaning the car is definitely peppier around town. Peak boost is mechanically limited and unchanged from what I saw but the car is def quicker down low for me. A10 here 2019
Old 04-07-2020, 12:21 PM   #28
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Thanks for the tips and awesome pics and directions.
'20 ZL1 Black "Fury"
