Old 10-19-2020, 11:15 PM   #15
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Originally Posted by UnknownJinX View Post
Quick snip of the backup lights at the gas station.
So much better now.
Sent from toaster or something
LOVE my LED Reverse Lights on my 2020 2SS, why didn't Chevy do this from the factory???
Old 10-20-2020, 12:20 AM   #16
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Love mine as well. I can actually see things behind my car now at night.
I was gonna say that at least halogens would be easier to swap out should they fail(versus the whole taillight for an LED assembly), but then I realized that, with how much reverse lights get used, the LED bulbs should last the life of the car, or at least they wouldn't fail before the brake lights or running lights, which come on more often.
The annoying thing is that you have to hack the LEDs in some way(either with a small resistor or a harness) to make them work properly. At least on my RX-8, I could just plug and play LED with zero issues. Most other cars seem to be like this as well.
My C7 had LED reverse lights, so it's probably penny-pinching on the Camaro.
Just as a footnote, there was a guy at a Tacoma forum that tested a bunch of bulbs in reverse lights, and actually found that the brightest bulb is not an LED. It's an HIR incandescent that you can retrofit into the socket. It actually put out more light since it utilized the housing better than LEDs as it's still an omnidirectional light(LED is directional) while the HIR coating made the bulb burn brighter on roughly the same wattage. The Tacoma uses 921 bulbs, so I don't know if such an option exists for 7440 sockets. It's not the prettiest as it's still a halogen bulb so it emits a yellowish light, but it would be easier to retrofit with no resistor or harness required and would give better light output if that's your goal.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 10-20-2020, 12:47 AM   #17
2SS Capt
2SS Capt's Avatar
The LED Harness isn't that hard to retrofit on the Camaro and in my opinion is well worth the effort as it affords a TREMENDOUS amount of rear view lighting...
Old 10-20-2020, 12:59 PM   #18
NeXvZEiN
Drives: 2022 Alfa Romeo Giulia Quadrifoglio
Originally Posted by Zapote21 View Post
With the ijdmtoy kit mentioned above, each bulb has its own harness and resistor. No need to remove the bumper. Simply change the bulb and attach resistor as shown on these pics.
How did you attach the resistors? Planning on doing my install Saturday.
NeXvZEiN is offline   Reply With Quote
Old 10-20-2020, 01:26 PM   #19
UnknownJinX
The harness is pretty expensive, though. 90 US plus shipping to Canada, and we are looking at at least 150 Canadian. I already spent a lot on these LEDs. VLEDs bulbs aren't cheap, but their quality is pretty good.
That's why I thought I'd try the resistor first. 2 dollars for a pack of 4.
Current:
Past:
Old 10-20-2020, 04:17 PM   #20
Zapote21
Tampa Bay Camaros
Zapote21's Avatar
Drives: 2017 Krypton Green 2SS
Here you go:
Me and wife, in order
2011 2SS SGM
2013 2SS Hot wheels vert
2016 C7 DSOM
2012 2SS yellow vert
2017 2LT Krypton Green
2018 2LT Hot wheels crush
2020 2SS Shock vert.
2017 2SS Krypton Green coupe
Zapote21 is offline   Reply With Quote
Old 10-21-2020, 10:33 AM   #21
NeXvZEiN
Here you go:
Sorry, I meant to ask what did you use to mount it?
Old 10-21-2020, 10:52 AM   #22
Zapote21
Tampa Bay Camaros
Zapote21's Avatar
3M double sided tape
Sent from my Note 20 Ultra 5G using Tapatalk
2011 2SS SGM
2016 C7 DSOM
Old 02-17-2021, 10:42 AM   #23
jaybee924
Drives: R.I.P. 2021 ZL1 & 2019 Rd Garn 2SS
Okay I have a question. I have a 2021 zl1 at very little to no light at night in reverse the screen is dark, shadowy, I can barely see what's around around me and at the two top corners is a dark patch in each corner. The dealer can't duplicate the problem I've taken it twice which they don't have the background and with the lighting of the lot the place to really check it. I can see stuff in the daytime but I think the screen is a little fuzzy which I can deal with but need to be able to see at night that's more important.
Now my girlfriend has a 2019 2SS and under the same little to no light condition we can see everything.
Was my girlfriend 19 camera a luck of the draw or did y'all have the backup camera issues like I have with my 21? I don't want to add the led kit if I don't have to. Cause if I have an electrical issue then I have to pull that stuff off cause if they find it they may try to link that to the troubles.
jaybee924 is offline   Reply With Quote
Old 10-21-2022, 10:45 AM   #24
ls1smokedu
Drives: 2020 Camaro 2SS
I just ordered the iJDM ones mentioned in here - going to try them this weekend. Is anyone having any problems with them? It says it doesn't stay lit and doesn't interfere with the backup camera - does it cause battery drain? Winter is coming here soon and the car will possibly sit for a week or 2 without being started.
Thanks!
ls1smokedu is offline   Reply With Quote
Old 10-21-2022, 02:11 PM   #25
ls1smokedu
Update - the ones from Ijdmtoy work! They don't stay on and don't cause the backup camera to stay on. All the others I tried had both issues
Old 10-27-2022, 02:49 PM   #26
tommy21LE
Drives: ‘21 2SS 1LE A10
these from Diode Dynamics along with their resistors worked best for me
https://www.diodedynamics.com/backup...maro-pair.html
tommy21LE is offline   Reply With Quote
Old 10-27-2022, 05:36 PM   #27
They have figured out the resistance problem all right, I have their turn signal bulbs in the front (mine is a 2018) and those are perfect, too, no hyperflash with just the bulbs and zero extra harness or resistors.
