#15 |
I got lucky and didn't break my stock drive shaft but I did break a GForce Aluminum DS at the LS Fest last year and I did have a BMR Loop I now run a Chromoly DSS. Even without a loop the drive shaft is not coming out the bottom if you have full exhaust. Its a pain in the ass just to get it out on a lift with all the shit you have to take out but could damage other shit underneath and the floor. Hope everything is ok and just need a new DS. If you have big power trailer your car to the track.
#16 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
Guys, remember that this car is a ZL1, that has a stronger driveshaft than our SS cars came with. Seen plenty of guys posting 9-second slips with stock ZL1 drivelines, this is the first time that I've seen someone report a ZL1 driveshaft breaking.
As far as replacement options, I have seen a QA1 carbon shaft (for an SS) and that thing looked pretty beefy. Advertised to handle 1000 lb/ft of torque, it was slightly lighter than an SS shaft, so probably noticeably lighter than the ZL1? I know someone that installed a carbon shaft on a CTS-V3 (another LT4 car) and he said that the carbon shaft was noticeably lighter than stock in that case. |
#17 |
![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I won’t be able to look under the car until tomorrow but will probably be ordering new driveshaft and stronger axles to go with it. The track here used to be crap but now under new management and at bout 200 ft my shoe was coming off my foot. Sticky like crazy!
#18 |
Car will now be trailered to the track.
#19 |
![]() Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
Gotta ask, how far away was the track and how did you get her home?
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
#20 | |
I still have no idea what this car can do. First pass I launched at about 1000rpm and did 1/3 throttle for the first 100ft then punched it. 60’ was a 2.0 with 11.1 time at 137mph. Second run broke. |
#21 | |
Moderator
I think we’ve all had the flatbed experience at some point. Maybe my last run of the year will make you feel better...lol. 104 miles from home... I told AAA that I drove out to the track to see my friends race but my car wouldn’t move for some reason...
#22 |
![]() ![]() Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
I snapped a half shaft and called GM roadside assistance.....they towed me home for free lol. I have a trailer now and have needed it, I cheaped out and bought a manual winch instead of the electric. I would recommend spending the dough for the powered unit.
#23 | |
![]() Drives: 2017 1SS A8 Nightfall Gray Join Date: Feb 2017
#24 |
I've broken 2 axles, trans and diff on my C5, it hated Drag Radials. Diff on my Maggie G8 (did not have a trailer on this event) and cost me a bunch to get my car home from 200 miles so that will never happen again. Plus the Gforce on my SS at the LS Fest. However the trans and diff are still original with 12800 miles and 230 or more passes. On my 3 motor, dam I'm hard on stuff.
#25 | |
![]() Drives: 1968 Camaro and 2019 ZL1 Join Date: May 2019
#26 |
The tires are ET street R. I had them at 22psi. Burnout for 6 seconds was a bit longer than I wanted but the line lock would not release. Would prefer about 3-4 seconds. Once I get everything fixed and sorted out I’m sticking with that psi unless the track dictates something else. First pass I felt no wiggle on the big end with that pressure and trap speed was on point. I’m pretty confident that the car will do a 140mph trap with good launch and everything holding together.
#27 |
You'll get it lined out and back to the track. If you can trap at 140 you'll probably be in the really low 10's or high 9s. I ran 9.83@140 with my 2300 Maggie last spring before we went to the 2650. I did trap 149 one pass at the end of last year but most of the time 146 to 147 on almost every pass.
#28 | |
