Old 02-29-2020, 10:39 PM   #15
SgtRick
Drives: 1968 Camaro and 2019 ZL1
Originally Posted by gotswap View Post
Have some wheels coming in the below specs and am wanting to run 315/30r20 rear and 295/30r20 front. Anyone see any concerns with this before I order tires?
2019ZL1, stock suspension
20x10.5 20mm offset front
20x11.5 48mm offset rear
I think your 48mm offset will cause your tires to rub on the liner. I know I use Forgestar F14 rims with 44mm offset and my 305/45/17 barely clear the inner liner. I moved the wiring harness for safety.
SgtRick is offline   Reply With Quote
Old 03-01-2020, 10:31 AM   #16
Intimidator
Drives: 69 GTO, 05 GTO, 2018 Silver ZL1
I have Polished MRR FSO5 and Drift R wheels.
Both are 20x10 (+20 offset) and 20x11 (+43 offset)
I am running 295/30/20 and 325/30/20 SC2 on the MRR with ZERO issues.
Intimidator is offline   Reply With Quote
Old 03-01-2020, 10:53 AM   #17
Markoz28
Drives: 18 ZL1 nightfall grey A10
Thanks for the info I'm about to throw on 20x11's with a +43 offset and 315/30 tires once the car's out of hibernation, and been wondering if I can get away with it and not use spacers.
The liner is no problem, but of course I want to ensure proper fender and suspension clearance, plus wheel-size.com says that'll make the scrub radius negative 7, which is suboptimal for the ride, but I guess I'll have to try and see
You should have no problems with that set up. I would still move the wire in board. Just for peace of mind.
Markoz28 is offline   Reply With Quote
Old 03-01-2020, 12:22 PM   #18
Done, Sir. Thank you again for the input.
Old 03-02-2020, 08:46 AM   #19
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
If I do need to run a spacer to push the wheel out. What is the max recommended safe thickness before needing longer studs?
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 03-02-2020, 09:13 AM   #20
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Picking up a friends OEM zl1 1le's today 19x11 ET11mm 19x12 ET41MM..
Gonna run the 295 25 30 up front from the ACR viper kumho v720 track tire $180.00ea
Rear I will take off the 345 30 19 R88Rs and through them on the zl1 1le oem 12 inch rim right now they are on the Mrr reproductions.
Probably go with something quieter and less expensive to replace than the R888Rs for daily driving...
Had good luck with the PS91 kumho on the SS quite and good wet traction and dry traction!
You need something that can hold the eforce! gotswap!
Old 03-02-2020, 09:50 AM   #21
gotswap
gotswap's Avatar
Tell me about it, the 980A/S are great in the weather but they don't like the power
I am really leaning to the new Advan tires
2019 Crush A10
E-Force 2650
670WHP 615WTQ
Old 03-02-2020, 10:19 AM   #22
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
ya there 2 on ebay for 399.99 right now..
I saw 2 PZ4 corsa new for 399.00 not the old 5th gen crap these are Mclaren or lambo oem tires with good tread and 80 AA tread life so super soft!
Old 03-02-2020, 01:10 PM   #23
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Following to see if this MASSIVE 2.34" tire diameter difference renders your car unmovable or not.
Old 03-02-2020, 01:19 PM   #24
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Running 345 for last 8 mos gonna try 355 next time
Old 03-02-2020, 01:52 PM   #25
TheRealJA105
Drives: 2013 C6Z06
Running 335 for last 8 mos gonna try 355 next time
With 295/25 fronts? That's what I'm concerned with, the F/R diameter difference.
Old 03-10-2020, 10:29 AM   #26
Now that I have seen and tried things, I'd say 5 mm is the absolute max, it leaves 8 threads engaged with the OE studs.
Old 03-10-2020, 12:42 PM   #27
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
What's the concern?
Old 03-10-2020, 01:20 PM   #28
Markoz28
A 295/25/19 is a very thin/short tire. Not sure why you would want that?
