Old 03-23-2020, 05:19 PM   #15
bng349
bng349's Avatar
Drives: 2019 Camaro 1SS
Here's photo of the Flowmaster Scavenger series and the stock midpipe portion it replaces. Stock looks restrictive specially that flattened section towards the rear. I planned on getting this since I already have the American Thunder axleback.
bng349 is offline   Reply With Quote
Old 03-23-2020, 08:30 PM   #16
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
The Flattened section does not affect power. Tests have proved this. For an OE system the C6 system is actually pretty darn good.
Old 03-24-2020, 03:03 AM   #17
StormTrooperCamaro
Drives: 2017 Summit White 1SS
I’m not super Interested in the power gains from an x pipe like this. I’m just itching for more sound from my Flowmaster system without deleting the cats
StormTrooperCamaro is offline   Reply With Quote
Old 03-24-2020, 05:06 AM   #18
ss2fast4u
2018 Camaro 1ss M6
Drives: 2018 Camaro 1SS M6/ LT4 SC
Originally Posted by StormTrooperCamaro View Post
I’m looking to keep my secondary cats, do you think it will make much diff
If I have the American thunder system already?
removing the secondary cats really opened up the sound in my opinion. I will try to get sound clips just been stuck at work and the weather has not been great.
ss2fast4u is offline   Reply With Quote
Old 03-24-2020, 04:50 PM   #19
bng349
bng349's Avatar
Thanks for the info. Do you happen to have the links to those tests? Looking at the photo, I just can't see how that flattened section offers same volume of air to pass.
Old 03-24-2020, 05:03 PM   #20
enzia35
Drives: '16 Garnet Red 1SS
https://www.mishimoto.com/engineerin...he-crimp-myth/
'16 Camaro 1SS
'18 Miata GT
Old 03-24-2020, 05:12 PM   #21
s346k
s346k's Avatar
Drives: like an old lady
ive spent some time around around a car with kooks long tubes, high flow cats and no secondary cats. it was a touch louder than my car when it was stock and making pulls resulted in a doorhandle race, every time. both cars 1SS 1LE. secondary cat removal not worth the effort imho
Old 03-24-2020, 05:40 PM   #22
bng349
bng349's Avatar
Old 03-25-2020, 11:42 AM   #23
StormTrooperCamaro
I mean I have considered a secondary cat delete. My car is my daily though and I live in Cali, so I’m a little Paranoid about messing with my cats
Old 04-20-2020, 01:15 PM   #24
njweatherman
Drives: 2018 Camaro 2SS, redline edition
Does anyone know what the AFM valves look like on the Flowmaster Scavenger Series X-Pipe for automatics? I'm wondering if they look and perform the same as GM's OEM.
njweatherman is offline   Reply With Quote
Old 05-04-2020, 12:03 PM   #25
StormTrooperCamaro
Bump
Old 05-04-2020, 04:05 PM   #26
njweatherman
I emailed Holley.com and they said, the following:
They do not use the same size valve as would come factory, but do utilize the same actuator motor and function the same as OE.
Old 05-05-2020, 12:04 PM   #27
Spartan268
Spartan268's Avatar
Drives: HB 2SS
Which would make sense since the Flowmaster is a 3 inch system so the valve will be slighter bigger.
Spartan268 is offline   Reply With Quote
Old 05-05-2020, 02:57 PM   #28
njweatherman
I just had mine installed a few days ago.
It is definitely louder and deeper when you accelerate.
Maybe a little louder at idle.
Speed and performance wise: a little faster on low-end.
BTW - a tight fit near the AFM valves on the driver's side due to the proximity to the transmission cooler lines.
Hope this helps!
axle back, exhaust, flowmaster, npp, x pipe
