Old 01-13-2020, 07:34 AM   #15
Biscuit.fr
Drives: Red hot ZL1 A10 2017
Anybody has the ref of the 0w40 oil cap?
Or a link to get one ?
Tx
Biscuit.fr is offline   Reply With Quote
Old 01-13-2020, 08:29 AM   #16
Krowser
Krowser's Avatar
Drives: ZL1 Mosaic Black
Tx
12686472 – 2019 Corvette Stingray w/o Z51
12680708 – 2019 Corvette Stingray w/Z51, Grand Sport, Z06, ZR1
Krowser is offline   Reply With Quote
Old 01-13-2020, 08:59 AM   #17
Krowser
Krowser's Avatar
Originally Posted by Stephen12ZL1 View Post
For Street use you're totally fine using 5w30 dexos 2 Mobil 1. 0w40 ESP Mobil 1 is a good all-around Street / track oil
Here is my breakdown and reasoning behind the oil viscosity uses:
5W 30 is sufficient for NORMAL street drivability, i.e. normal freeway driving, grocery getting and stop and go traffic. Down side: 5w 30 evaporates more than heavier weighted oil under heavy use. This oil also thins too quickly under repeated heavy use due to moisture and unburnt fuel blowby. 5W 30 will thin after 1 or 2 heavy use cycles and will no longer perform like a 30 weight oil.
0W 40 is for the street warriors and track use: track course, freeway pulls, drag racing, roll racing, normal freeway driving, and even grocery getting. Down side: The cost of this oil is expensive. Drivers should allow for at least 2 minutes of warm up time after starting a cold engine. Must use PF64 oil filter for flow and for warranty.
15W 50 is for guys that perform: heavy freeway pulls, launches, heavy track course, heavy drag strip, heavy roll racing, heavy freeway pulls etc..Down side Over prolonged use, this oil does not lubricate as efficiently as 5w 40 or 0w 40. This oil requires long warm up times from cold starts. This oil does not play nice with cats. IMO must use PF64 oil filter due to heavy viscosity of oil because PF64 has larger inlet holes..even bigger than PF64R. Must use PF64 oil filter for flow and for warranty.
I think the majority of readers here fall into the 0w 40 catagory!!
Old 01-13-2020, 10:15 PM   #18
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Cars and Coffee or "cruise in" crowd stick with 5w30...
Old 01-13-2020, 11:19 PM   #19
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
��Stephen!
Old 01-14-2020, 05:11 AM   #20
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Originally Posted by dbvettez06 View Post
Owners manual says 0w40. And 5w40
The oil cap says. DEXOS 5w30.
What the heck gives ???????
5w30 Dexos is what I would do in Colorado for street driving. 0w40 is a slightly higher viscosity (and ~2x the cost) and what I use in FL for same.
Tx
$11
https://www.amazon.com/gp/product/B0792NR4C6
Old 01-14-2020, 02:45 PM   #21
Biscuit.fr
Tx for the ref.
Old 01-14-2020, 06:47 PM   #22
Badmojo
aka BeastZL1
Badmojo's Avatar
You do realize that a 5W30 has a higher viscosity at cold temps than a 0W40 right?
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 01-14-2020, 08:37 PM   #23
Zigg L1
Zigg L1's Avatar
Drives: 2018 ZL1 Garnet Red Tintcoat A10
I think the debate between 5w30 or 0w40 depends on where you live and how you drive. I myself live in NY and don't have super high temps alot. So I might benefit from using the 5w30? 5w30 is thinner at cold start this coating the engine components better sooner. Yes 0w40 would be best for hard driving and track.
Does this sound right?
Zigg L1 is offline   Reply With Quote
Old 01-14-2020, 09:34 PM   #24
Badmojo
aka BeastZL1
Badmojo's Avatar
5W30 has a higher viscosity at start-up. It's the 5.
The SAE classification for multi-viscosity oil consists of two viscosity grades, such as viscosity SAE 10W-30. The first part of the grade (10W) is the comparable grade of the single viscosity oil that features the oil’s weight at cold temperature.
The second part of the grade (30) is the grade of the comparable single viscosity oil that defines its viscosity at 212 degrees Fahrenheit. You should note that both parts of the multi-grade SAE classification are not viscosity values but grades.
2019 Camaro ZL1 1LE
Old 01-15-2020, 09:10 AM   #25
2019ZL1Droptop
2019ZL1Droptop's Avatar
Drives: 2019 ZL1
I went to my local Chevrolet dealer yesterday and confirmed what I can & can't use for motor oil. Based on my 2019 ZL1 Convertible Vin# this is what the parts guy printed out for me.
The 5W-30 Dexos 1 Gen 2 GM motor oil is also reasonably priced ($6.29 CDN) versus the cost of the Mobil 1 ESP 0W-40. If I was going to be heavy footed and drive the pants off the car, I would consider using the Mobil 1 0W-40.
2019 ZL1 M10 Convertible
Shadow Gray Metallic
SIGPIC][/SIGPIC]]
2019ZL1Droptop is offline   Reply With Quote
Old 01-15-2020, 09:57 AM   #26
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
15W 50 all the time. Not switching back to 5w30 for a few weeks and a hundred street miles between track events.
Pollock is offline   Reply With Quote
Old 01-15-2020, 12:43 PM   #27
hawk02
Coupe Newbie
hawk02's Avatar
I've been putting nothing but Mobile 1 ESP 0W-40 in my ZL1 since the summer of 2018. I found there is a small but noticeable difference in acceleration smoothness and over engine performance with the 0W-40 versus M1 5W-30. Even though I don't track my car, I feel the performance gain from the 0W-40 oil is worth the extra cost.
Old 01-15-2020, 01:08 PM   #28
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
I thought that it was the placebo effect.
