Old 01-04-2020, 08:48 AM   #15
IH8WNTR
Drives: 2017 1SS 1LE Silver Ice Metallic
Originally Posted by Og Neon View Post
I took a page out of the Z06 guys I ran with in Az and made up two different designs that I can quickly install giving me two different levels of sound reduction depending on what I need. Here is one of the designs installed that give me a minimal redux in sound. I don't have pictures of the other set, but they go straight out as an insert with some sound baffling material inside.
How do you fasten them to keep them from falling off or being ejected?
IH8WNTR is offline   Reply With Quote
Old 01-04-2020, 08:57 AM   #16
Rodan
Drives: 2018 ZL1 coupe
If you look closely, there's a threaded rod on the bottom that likely goes forward to a bracket welded under the stock pipe. He's got tubes for the threaded rod on top and bottom, so the tips can be rotated 180* depending on which side of the track the sound equipment is on.
Rodan is offline   Reply With Quote
Old 01-04-2020, 09:03 AM   #17
IH8WNTR
Oh I see. Clever. I may be looking into doing something like that. Thanks!
Old 01-07-2020, 12:37 PM   #18
Jimbeau11
Jimbeau11's Avatar
Drives: '18 Black SS 1LE; '01 Corvette Z06
I don't have pictures but the Porsche Cup cars used to drill holes and crisscross safety wire over the tips at Roebling Road to knock a couple of decibels off.
Jimbeau11 is offline   Reply With Quote
Old 01-08-2020, 11:55 AM   #19
rickybobby
Drives: BMW M3, ZL1 1LE
Please post pics of your setup.
Here you go. Simply slide them in and tighten one bolt. No issues at full throttle on a 90db day.
And it sounds even better down the front straight because it directs the sound towards the wall 😂
rickybobby is offline   Reply With Quote
Old 01-08-2020, 01:10 PM   #20
Rodan
Thanks!
How does the 'one bolt' work on your setup? Through the bottom of the tip? i don't see any external brackets...
Old 01-08-2020, 01:29 PM   #21
rickybobby
Thanks!
There’s a u-hook that attaches to the exhaust bracket. I’ll get a pick when I have a chance to pull them out.
Old 01-08-2020, 10:22 PM   #22
JRL1LE
JRL1LE's Avatar
Drives: 2017 SS 1LE
I use this at Laguna, no problems on 90 db days
JRL1LE is offline   Reply With Quote
Old 01-19-2020, 05:00 PM   #23
Rodan
I started from scratch and fabbed up a new 'noise abatement' strategy today.
I cut off the stock tip, and welded on V-band flanges to re-mount it, then made a second 3" extended tip with a 90* turn for each side to re-direct the sound.
Easy to swap, and they can be rotated to change direction for different tracks.
I only bothered with the outboard tips, because that's where the exhaust goes (bypassing the muffler) in 'track mode', when the valve is opened up. Any gasses going through the muffler will be quiet enough that I'm not worried about the inboard tips.
Interestingly, the size of the actual stock exhaust at that point is 2 1/4"... my turnouts are 3".
I may shoot them with a coat of high-temp black paint, but I'll wait to see if they pass sound first.
Old 01-19-2020, 08:02 PM   #24
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Nicely done!! I may have to visit my local custom exhaust shop before this upcoming season starts. Tracks are NOT getting any more sound friendly that's for sure, so I need to come up with a db solution on standby for when it WILL be needed.
driven2exceSS is offline   Reply With Quote
Old 02-22-2020, 08:22 PM   #25
Rodan
So I shot them with some high-temp paint, and today we passed sound at our 95dB track...
