Old 12-16-2019, 11:29 PM   #15
puppykat33
puppykat33's Avatar
Drives: Black 2019 ZL1 M6,
Originally Posted by Vtor_ZL1 View Post
I would not add any points of failure in such critical area.
You think this might be a failure point and to not risk putting something like this in?
What is everyone elses opinion? Dont risk it for something as simple as a cleaner way to change oil? This is kind of why i posted it to get others opinion if it is a good idea and see how many people use them on their baby's.
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
puppykat33 is offline   Reply With Quote
Old 12-17-2019, 02:23 AM   #16
Dixie ZL1
NOXQCES ZL1
Drives: 2017 Camaro ZL1
No failure risk..... spring pressure + weight of 10 qts of oil keeps the valve closed and safety cover adds peace of mind.
This and quick jacks make oil changes a pleasure.
Dixie ZL1 is offline   Reply With Quote
Old 12-17-2019, 08:28 AM   #17
PROMETHEUS
PROMETHEUS's Avatar
Had it on my Corvette for 2 years and then moved it over to my ZL1, for the past 10 months. The only problem I had was a small leak from the copper crush washer, while it was on the Corvette. I contacted Stahlbus and they indicated they had gotten away from the copper crush washer "because of leaks" and replaced it with a rubber like one, which they subsequently sent me.
The problem with the crush washer is you can not crank on the bolt, like an OEM one, because it is hollow. I don't remember the max torque, but it was very low.
Since the new washer...no problems.
It takes a little longer to drain the oil, but the "less mess" is worth it, to me!
Old 12-17-2019, 08:53 AM   #18
puppykat33
puppykat33's Avatar
the Stahlbus and the valvomax look the same basically. Side note for the people using magnetic plugs. Do you ever have any metal on the magnet during oil changes?
Old 12-17-2019, 09:49 AM   #19
Ebbsnflows
Drives: 2018 Camaro ZL1-1LE
Stahlbus looks interesting. I've been using the Fumuto drain valves for years and have been pleased with them. They are the lever/ball-valve style. Draining is a matter of attaching the hose, and turning the lever.
2018 Camaro ZL1/1LE
Ebbsnflows is offline   Reply With Quote
Old 12-17-2019, 09:50 AM   #20
PROMETHEUS
PROMETHEUS's Avatar
I suspect, same design!
Old 12-17-2019, 12:24 PM   #21
viurniel
@viurniel
viurniel's Avatar
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT
Dusty residue. Nothing crazy, but it picks up stuff.
viurniel is offline   Reply With Quote
Old 12-17-2019, 01:37 PM   #22
puppykat33
puppykat33's Avatar
Yea i cant decide if i want to go the magnetic route for protection, or the easy no mess route. So many decisions ...
Old 09-16-2023, 03:06 PM   #23
DarkMaroSS
DarkMaroSS's Avatar
Drives: 2018 Camaro SS (sold)
Originally Posted by LiqTenExp View Post
I use the Stahlbus, best thing ever for maintenance.
https://www.amazon.com/Stahlbus-Drai.../dp/B01AMXATSC
Definitely getting one for my 2018 SS. Funnt that Amazon says it does fit the car!
2018 Camaro 1SS | BBK 92mm TB | GPI Ported LT1 Manifold | ColdAirInductions CAI | Granatelli Wires and MSD coils | Mishimoto Catch Can | GMP Black Strut Tower Brace | NPP Exhaust and 2nd Cat Delete | Recaro Seats | GM Stainless Sport Pedal Kit | GM Carbon Fiber Shift Knob | Deck Lid Spoiler with Wicker Bill | Smoked Sequential Taillights | Smoked Third-Brake Light | 1LE Front Splitter/Satin Black | ZL1Addons Splash Guards
2015 Camaro SS/RS (Sold)
DarkMaroSS is offline   Reply With Quote
Old 09-16-2023, 06:02 PM   #24
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I thought my fumoto was a great brilliant idea until it took 30 min to drain at a trickle 10 qts from the too small orifice. Complete waste IMHO. The idea is brilliant but in practice, i think its a fail.
Old 09-16-2023, 07:14 PM   #25
SwL_Wildcat
SwL_Wildcat's Avatar
Drives: 2024 ZL1
No Spill makes them as well. We use the larger versions on the heavy equipment. It will drain 40 litres of hot oil in about 5 minutes. If the oil is cold it takes closer to 30 minutes. This one is 12mm x 1.75
https://nospillsystems.com/product/15-12175-05/
SwL_Wildcat is offline   Reply With Quote
Old 09-17-2023, 04:03 AM   #26
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
This brand is what I used for my transmission oil pan mod, but I use it for refilling not draining. We use them on all our big trucks at work for draining, it is a high-quality product.
