#15 |
Thank you Al Oppenheiser!
I got 99 issues, but with my Z there ain't one.
#16 |
Pizza & Wings Only $12.99
Drives: 2017 Camaro SS Join Date: Jan 2012
I've definitely had some issues.
I had an area of the car that basically had no paint, but it had a clear coat. Got it fixed. The trunk and hood rattled. Hood was loose. Got it fixed. Trunk was out of alignment. Got it fixed. Had the end links come loose multiple times on the car and one time the spring wasn't seated correctly. How? Who knows. I finally got some aftermarket endlinks, nordlock washers and loctite. Still rattled. That's how I found out the spring wasn't seated correctly. The manual transmission was a bit noisy but every manual car I've owned has always been noisier than an auto. My car would have trouble restarting after shutting it off when the engine was hot. The starter seemed to have a heat soak issue. Never got it fixed. It never left me stranded anywhere. It sounds to me what you really need is a much louder exhaust.
H-Town Camaro Club
Past Rides: 2012 Camaro 2SS/RS M6 2012 Camaro ZL1 A6 2017 Camaro 2SS M6 |
#17 |
#18 |
Drives: Camaro SS 1LE Join Date: Aug 2018
Rattle from driver air vent and ticking from front wheels. The ticking has been fixed.
#19 |
NOXQCES ZL1
Drives: 2017 Camaro ZL1 Join Date: Mar 2019
Yep.... troll
#20 |
![]() ![]() ![]() Drives: 2016 SS Convertible Join Date: Sep 2016
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Some of us definitely have had issues. Just check the Issues subforum.
I had a spun camshaft bearing requiring a new engine under warranty at 57,000 miles. I also have the starter heat soak problem. Car struggles to re-start when the starter is hot. Pretty embarrassing at times. Sounds like the battery is low or starter is dying but only does it when hot. Clunk in the rear in when cold. Windshield wiper pump died, replaced under warranty. Catalytic converter had a crack causing exhaust leak. Replaced under warranty.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
#22 |
![]() Drives: 2016 Chevy Camaro 2SS Join Date: Nov 2019
#23 |
#24 |
![]() Drives: 2019 Chevrolet Camaro SS 1LE Join Date: Nov 2016
To fix this issue you need to remove the knee pad and line the perimeter with felt. This should NOT be an issue on a new vehicle (or near new vehicle), but at least it's easily resolved.
#25 |
![]() Drives: 2017 Camaro 2SS Join Date: Mar 2019
Racked my brain and finally came up with an issue, the car is great actually after the shudder service bulletin and steering recall service. Sometimes when I pull up to my parking spot at work which has an off camber entry onto a slight ramp, the sunroof creaks a little if I had it open prior to entering the parking spot. All I got...
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon |
#26 |
![]() Drives: Chevy Camaro Join Date: Jul 2019
Drive an F body as a daily like I do you'll stop your bitching,
#27 | |
Long hauler
#28 |
Oh wait I got one. My truck latch was loose. So I tightened it. Perfect Now !!
| Tags |
| boost, differential, paint, rear end |
