#15 | |
![]() Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
https://grassrootsmotorsports.com/ar...r-cylinder-ca/ I just bought a base 2.0T specifically for autox and daily use. It's got 305 BFG Rival S 1.5 going on all around tomorrow. I'll also probably head out to VIR once this year, but it'll be hard to keep up with the extra power of the V8s out there. As far as I'm concerned, the extra speed on the straights just means more consumables and being closer to death though. |
#16 |
![]() Drives: 18 Camaro LS M6 Join Date: Apr 2019
Whats an "anti-lag tune that eats turbos tune"?
. . NFG M6 2T Mishimoto Hot side pie | ZZP Catted DP | KN Drop in | Borla - Sport Tour | Apex Arc 8 - square | Wookster Tuning+ | Flex Fuel Last PB 4.8, 13.2@106 |
#17 |
![]() ![]() Drives: 2016 M6 2.0T Join Date: Nov 2016
[QUOTE=foshjowler;10723180]At Nationals, the 2.0T driven by a couple GM guys won CAM class, which was made for the v8 muscle/pony cars. They put on an anti-lag tune that eats turbos, but they claimed they had more torque than the V8s coming out of corners. Not that power gives you much at autox, the lower weight and 50/50 balance for the 2.0T will probably negate any advantage of the power.
https://grassrootsmotorsports.com/ar...r-cylinder-ca/ Great article. I love coming across things like this. Are we just going to sit here and ignore the fact that they installed the "SS" Strut Tower Brace with no fitment issues... Lol Also, what's up with the water cooler they fitted to the stock intercooler??? I kind of want to do that....
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
#18 |
#19 |
took a bit but I found some info thanks. Big in the rally world.
"Anti lag was devised to keep the turbo spinning in a throttle off position. A very late ignition spark (~30° retart and overfuelling causes the flame front to exit the engine through the open exhaust port.-- Read more at: https://www.torquecars.com/tuning/anti-lag-systems.php - (c) TorqueCars"
#20 |
Might we see Mr Pobst go back to his roots in autocross with his new 2.0?
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Race Car Join Date: Sep 2009
#22 |
![]() Drives: dodge grand caravan, acura rsx Join Date: Apr 2019
They modified that 2.0. Hardcore. Zl1 suspension, and blowing turbos every 500-1000 miles. It's a money no object racecar and that does t count . Ss 1le much more affordable than that, slower, but much more reliable.
The had an extra 100 hp and 100 two over stock. |
