Old 12-02-2019, 02:44 PM   #15
Mick0311
Drives: 2018 Camaro 2SS Redline
Torque specs have a dry, wet and PTFE scales. If you use anti-seize, use the wet scale. Simple enough.
Lots of people saying they put these together dry yet not a lot of talk (now there will be) of taking them apart.
Mick0311 is offline   Reply With Quote
Old 12-10-2019, 11:25 AM   #16
Idyll
lost between two shores
Idyll's Avatar
Drives: 2020 SS 1LE
Of course you can put bolts in dry and w/o anti-seize, but that's not the point of anti-seize. The point of anti-seize is in the event you ever need to remove the bolts.
Introducing numerous high heat cycles to two different metals torqued together is a recipe for seizing, galling, cold welding, and heat freezing. This can become a huge nightmare if you ever need to disassemble. However, if you're 100% sure that you'll never need to undo what you torqued, then go dry if you want.
Using anti-seize is working smart, and to adjust for the extra lubricity simply reduce the torque specs by 20-25%.
2020 SS 1LE | Almost Mod Free
Idyll is offline   Reply With Quote
Old 12-10-2019, 11:32 AM   #17
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
I haven't used anything and have removed my headers quite a few times.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 12-10-2019, 11:49 AM   #18
Idyll
Idyll's Avatar
Drives: 2020 SS 1LE
Over what period of time?
Old 12-10-2019, 12:24 PM   #19
MP3BOOSTED
MP3BOOSTED's Avatar
My car has 9k miles on it, started modding it at around 6-7 miles back in early 2018, throughout that year til now i've removed my headers about 2-3 times, for cam install, heads install and now removing the motor from my car to install forged internals and go boosted.
Old 12-10-2019, 12:44 PM   #20
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
You don't need anti seize, I had headers on my fourth gen forever, they came right off, steal bolt, aluminum head, normally will not stick to one another.
ssmofo is offline   Reply With Quote
Old 12-10-2019, 12:48 PM   #21
MP3BOOSTED
MP3BOOSTED's Avatar
I don't even torque mine, get it tight and call it a day
Old 12-10-2019, 09:16 PM   #22
OVRKLL
Drives: 2017 1SS 1LE...makes me go YeeeHaw!
Thank you for the advice/suggestions.
I decided to go in dry and use the bolt locks that came with the Kooks...looks like it will do the trick should the bolts decide to back out.
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late!
OVRKLL is offline   Reply With Quote
Old 12-10-2019, 10:51 PM   #23
Idyll
Idyll's Avatar
Drives: 2020 SS 1LE
Google "broken header bolt".
Old 12-17-2019, 03:48 PM   #24
GTO_Gregory
GTO_Gregory's Avatar
Drives: 2016 Camaro
I use anti-seize when possible. It prevents the headache of frozen nuts and bolts. Just be careful around sensor surfaces, but that's not the case here.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff.
2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85.
GTO_Gregory is offline   Reply With Quote
Old 03-12-2020, 11:15 AM   #25
Idyll
Idyll's Avatar
Drives: 2020 SS 1LE
been putting headers on various vehicles going on 20 years now. never used antiseize.
Putting headers on w/o anti-seize is always easy.
Old 03-12-2020, 11:37 AM   #26
s346k
s346k's Avatar
Drives: like an old lady
you must have a story, given the contention. do tell.
perhaps i should have included that i removed almost every set of headers i installed (sans anti seize) and haven’t had any issues. had the same set off of an lsjuan motor several times over the last 5 years. a header bolt is about the only one i haven’t broken off in some part of the engine.
had the manifold bolts out of my 275k mile xj countless times with 0 issues, over the last 8 years.
anti seize is good stuff but simply unnecessary for header bolts.
Old 03-12-2020, 03:24 PM   #27
oldman
Drives: SS 6 speed of course
I used them dry with the locks pictures, none seemed to have rattled out, so after the 4th install, I don't bother with the locks... I know I should,,, but I never found one loose. IMO most people that put them on with the hand-torque wrench go too tight. I only use my hand as the torque wrench, has not failed in many decades...
