Old 11-14-2019, 08:59 PM   #15
ProjectZL1
ProjectZL1's Avatar
Drives: 2017 Camaro ZL1
Originally Posted by Can'tHave2MuchHP View Post
The eLSD requires a critical additive that is present in the OEM fluid. It's likely this additive that contributes to the higher price of the fluid; this isn't standard gear oil. I know people have purchased an additive on its own and attempted to add it but then there have been cases where it doesn't meld or mix properly. Isn't the extra $10, $20 or even $30 worth it for the peace of mind?
My thoughts exactly. I figured there was something special about the fluid for the ELSD.
Originally Posted by harner View Post
I always appreciate a good DIY video. Thanks for contributing to the community.
Thanks brotha!
ProjectZL1 is offline   Reply With Quote
Old 11-15-2019, 07:05 AM   #16
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Good video. FWIW, why try and out-think the engineers? They specified a particular fluid for a critical part of the drivetrain. The GM fluid keeps the diff quiet, is clearly engineered for track use, has no history of causing excessive wear or grenading differentials and will never be a reason to deny a warranty claim if there is a drivetrain problem. That is all worth a few “extra bucks” for the relatively few times you ever change your diff fluid.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 11-15-2019, 09:03 AM   #17
ProjectZL1
ProjectZL1's Avatar
Thanks man!
Old 11-15-2019, 11:04 AM   #18
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
The SS has a diff cooler anyway.
ssmofo is offline   Reply With Quote
Old 11-15-2019, 11:04 AM   #19
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
My compliments to a great video, too. I especially like the flushing.
'20 ZL1 Black "Fury"
Old 11-16-2019, 10:23 AM   #20
ProjectZL1
ProjectZL1's Avatar
Thanks brotha!
Old 03-30-2020, 10:35 AM   #21
getchapull
TEXIT
getchapull's Avatar
Drives: 2019 ZL1 M6
Update:
Changed the tranny fluid and diff fluid this weekend with Royal Purple Sychronmax and the RP 75-90 gear oil with friction modifier added.
Tranny seems to shift a little smoother, happy with the fluid so far.
Differential has not exploded yet. Drove 120 miles yesterday. Will keep my eye on it for any signs of disintegration.
Royal Purple is good stuff and I supported my local bidness.
getchapull is offline   Reply With Quote
Old 03-31-2020, 07:27 AM   #22
breakskeet
Kevin
breakskeet's Avatar
Drives: 2018 Callaway Camaro ZL1 1LE
Originally Posted by getchapull View Post
Update:
Not going to grenade. Nothing to worry about. I've been using RP Synchromax and RP 75W-90 in my ZL1 1LE which is now a dedicated track car with no issues. Car has about 3000 track miles and has run in the high summer heat at Sebring and the high banks of Daytona with zero issues.
breakskeet is offline   Reply With Quote
Old 03-31-2020, 09:48 AM   #23
Snowwolfe
Drives: CTV5 V Blackwing on order
Keep an eye on Amazon. Last week picked up 1 qt of the GM fluid for $13. Delivered free under Prime. But watch when you order, some companies charge a high shipping fee.
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10
2017 Ford Expedition
Snowwolfe is offline   Reply With Quote
Old 03-31-2020, 03:04 PM   #24
NorthGeorgia
Drives: 2018 ZLE, 2023 C8, IMSA MX-5
If you change diff and trans fluid often ... Load once and crawl under the car once. Also use similar setup (Motiv) for the brake fluid flush and bleed.
NorthGeorgia is offline   Reply With Quote
Old 03-31-2020, 04:26 PM   #25
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
ProjectZL1 nice video, thx
Old 03-31-2020, 08:15 PM   #26
20Bluezl1
You mentioned you had about 2400 miles I just picked up my 2020 zl1 and have about 3700 miles should I be changing it also? And at what intervals those GM recommend?
Old 03-31-2020, 09:35 PM   #27
Alain
Alain's Avatar
How do those work when it comes to brake bleeding ?
2018 ZL1 1LE/Red hot
Old 04-01-2020, 10:55 AM   #28
NorthGeorgia
I use the Motive brake bleeder - it has a pressure gauge and fitting (cap) that connects to the master cylinder. Add a liter of brake fluid, connect SECURELY to master, pump to 20 psi, then bleed each caliper (upper and lower). Usually have to re-pressurize the bottle a couple of times if flushing versus bleeding. One person 15 minute job. No more stressed wife pumping the brakes and premature pedal release.
Special NOTE 1. De-pressurize bottle before removing from master cylinder.
Special NOTE 2... Test the connection and pressure without fluid. You may have to use the larger extra rubber washer to ensure no leak.
Special NOTE 3 ... Re-read note 1
zl1
