#15 | |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
#16 |
![]() Drives: 2004 Z06, 2017 1LE Join Date: May 2017
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
the valve spring thing is not much of worry IMHO unless the "over-rev" rpm was extreme for a longer period of time. The higher than redline rpm didn't make the camshaft valve lift increase during the described incident. No doubt they were stressed. The events were occurring more rapidly but at stock valve lift you should be OK. With a high lift longer duration cam (with more overlap), this incident would have been potentially worse. Piston to valve clearance could have caused contact. Get an oil analysis and inspect the filter.
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
i thought some dude on here posted his experience with a money shift gone wrong and getting the engine repaired under warranty...? at least i recall seeing the vid on youtube.
#19 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Trade her in? (Not very ethical imo but i am sure this woudnt be the first, or a last time somebody punts trouble away.) The reason i have mentioned springs is that they are easy to change, not hugely expensive and - often enough - the cause of push rod motors going boom. Even if oil anaysis were perfect and no chunks seen anywhere at oil change i would change the springs for exactly the reason of piece of mind. But as i often say: that's me ![]() Cheers and best of luck to the OP! |
#20 |
Yes, there were more than one vids posted by folks who routinely over revved on downshifts. And got motors replaced regardless. Whether GM continues "no questions asked" attitude when honoring motor warranties is to be seen. As mentioned above, it would be easy for them to deny it based on over revs. Red line is there for a reason. Unfortunately manual tranny cant protect it on downshifts.
#21 |
Remember, these engines have the AFM / shifting lifters on cylinders 1, 4, 6, & 7. Even though AFM is not active on any ZL1 nor manual SS's, the hardware for AFM is all there. The AFM lifters do not take high rpm's as well as the regular lifters and are more prone to internal damage on over rev's. That's why they are replaced, typically, when aftermarket camshafts are put in because of the lobe profile differences along with the typical increase in fuel cutoff rpm put in aftermarket tunes.
Either way, over rev's causes valve bounce, valve spring bind & rotation, lifter over travel, etc. As TrackClub and others have pointed out, a single over rev can cause component failure - or not. Multiple over rev events can cause a component failure - or not. Any way you cut it, try not to over rev on up or down shifts. |
#22 | |
![]() ![]() ![]() Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
#23 | |
Tons of examples not only motor wise, but also other components. Run slicks on a street car long enough and one will be replacing hubs and control arms - guaranteed. Rotors and wheels can crack due to metal fatigue over time, etc. Bottom line: the fact nothing let loose is no guarantee it won't in a near future if it has been stressed beyond its operating specs. So the OP can get lucky, or his luck could run out at a next track event. Or one after that. Or whatever. In any case, i would caution against proclaiming everything is peachy, because that would be way premature a verdict imo and for whatever it is worth. |
#24 |
Heck - its' hard on valve springs just sitting with the key off! All sixteen of ours are under various static loads depending on where the cam lobe is for each.
#25 |
Very true. That's why those are first to get replaced especially on race motors that sit idle for a long time.
#26 | |
![]() Drives: 2018 1SS 1LE Join Date: Dec 2017
TC
Tango Charlie
'18 1SS 1LE '68 SS LS2 '89 RS 'vert |
#27 |
![]() Drives: 17 ss1le. Pray headcam e85 fbo msd Join Date: Mar 2017
Reading all this has me thinking about my recent smoking/oil burner. At my second track day with built heads cam motor that has ls7 lifters... engine started smoking coming out of corners at Grattan raceway Checked oil at event and by the time I got home after 160 mile drive I was down 1/2 quart. Have done several auto x events and only two tack events and never used oil or had visible smoke. I did miss shift once from 4 to 3 instead of 4 to 5 but didn’t catch on pdr. That was during first track event and didn’t smoke at all then. Going into builder in next few weeks to diagnose. After first track event car went in for new injectors and was a down a little on peak hp I’m no engine expert so appreciate any input on what I should be asking.
#28 | |
