01-20-2020, 09:32 AM | #15 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
That’s awesome! You won’t regret them. Yes, lots of ppl making serious power are using them and 315 is plenty of meat. For the street you will have plenty of traction. For the strip, you may want to consider drag radials if you make close to 700whp.
01-20-2020, 10:03 AM | #16 | |
Drives: 2017 ZL1 Join Date: May 2018
I'm only headers/rotofab/e85 at this point, so I should be good until the next round of mods. Can't wait to actually put the power down that I have! |
04-21-2020, 10:14 PM | #17 |
So you didnt have to do anything with the wiring harness or the fuel line? Just the offset was enough? What was the minimum offset you had to go with? Looks deadly
04-25-2020, 12:07 PM | #18 | |
The custom off set was bc I went with an 11.5” wheel. I wanted things to not just fit but look right too. If I were to do it again I would have done 42mm-43mm offset instead of 41mm just to be inside a bit more. But I have no regrets and love it. I can send some pics via txt to whoever PMs me their number. |
11-16-2022, 07:51 PM | #19 |
Drives: 2019 ZL1 Join Date: Oct 2020
I ordered the 325 30 r20 in the rear and they're supposed to be installed tomorrow. Will the tires shop know to move the wiring harness and stuff?
11-16-2022, 08:57 PM | #20 | |
The liner should also get a “Christmas tree” push clip to keep the liner from getting rubbed. https://www.camaro6.com/forums/showthread.php?t=485975 For visual reference. https://www.amazon.com/NWClips-Unive.../dp/B00DKM8BM4
