Old 10-13-2019, 05:47 AM   #15
zain
zain's Avatar
Drives: ZL1
Originally Posted by Badmojo View Post
FRONT 19x11" ET11 Anthracite APEX ARC-8
REAR 19x11" ET43 Anthracite APEX ARC-8
TIRES Bridgestone RE71R 305-30-19
1. No spacers in front, but limited to -2.0 front camber.
Looking Great!
zain is offline   Reply With Quote
Old 10-13-2019, 05:49 AM   #16
zain
zain's Avatar
Drives: ZL1
Originally Posted by Stephen12ZL1 View Post
Stock camber is OK clearance. -2.0° without the spacer, it is tight. You could grind the tab on the strut if necessary. The 5mm spacer was the easy way out.
Thanks for the info. From what I heard, Warranty could be voided if spacers are being used!
Old 10-13-2019, 06:28 AM   #17
FoundNemo
Drives: 2019 ZL1
Is there any risk in grinding that tab on the strut?
FoundNemo is offline   Reply With Quote
Old 10-13-2019, 06:29 AM   #18
FoundNemo
Drives: 2019 ZL1
How was the performance gain (acceleration change? steering?) going to this setup? It likely dropped 40+ lbs and thats similar to what I was considering doing.
Old 10-13-2019, 08:11 AM   #19
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Warranty concern due to a 5mm spacer? I'm confused. You realize the spacer can be removed in 2 minutes and 5mm isn't a big spacer. I can't think of one issue such a minimal spacer could cause.
Old 10-13-2019, 08:51 AM   #20
HogmanZL1
HogmanZL1's Avatar
Drives: 2018 ZL1 Convertible
Does the move to 19" affect he speedometer/odometer?
HogmanZL1 is offline   Reply With Quote
Old 10-13-2019, 09:27 PM   #21
Badmojo
aka BeastZL1
Badmojo's Avatar
It was 3-5 seconds on a 3.2 mile road course (NCM). The benefit was principally from changing to fresh RE71R's from half gone Goodyear Supercar 3's.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 10-13-2019, 09:28 PM   #22
Badmojo
aka BeastZL1
Badmojo's Avatar
Yes. 2-3 MPH at 70 MPH.
2019 Camaro ZL1 1LE
Old 10-14-2019, 05:23 AM   #23
FoundNemo
Drives: 2019 ZL1
So no noticeable performance from a roll for non-track use with the weight loss?
Old 04-02-2023, 04:23 AM   #24
SpiritedAway
Drives: ZL1 Convertible; 6-speed
Bump if anyone has pros to go down to 19”.
SpiritedAway is offline   Reply With Quote
