Old 09-29-2019, 12:09 PM   #15
SWZL11LE
SWZL11LE's Avatar
Drives: '19 ZL1 1LE
Originally Posted by s.hammer View Post
As others have said, the 3R grips well but does cord very quickly. I am running Nitto NT-01r and have gotten double the sessions of the 3R and still have yet to cord them. The NT-01 also wears far more evenly than the 3R. They may cost 50-100 more a tire but they easily have twice the rubber.
Running the track alignment? Are you cording the outside edge or the inside? Fronts or tears are cording ?
SWZL11LE is offline   Reply With Quote
Old 09-29-2019, 05:01 PM   #16
s.hammer
Drives: 2015 Z/28
Running track alignment. Fronts, I have corded one set on the outer and one set on the inner (no change in alignment spec, same 2 tracks). They just do not wear the same as other tires I have used on the ZLE or the Z/28 I tracked in the past. Rears have been decent wear across the tire. The 3R just not stand up to as much punishment on the fronts as other comparable tires.
s.hammer is offline   Reply With Quote
Old 09-29-2019, 05:35 PM   #17
kaamacat
Drives: 2018 ZL1/1LE Red
I am using the track alignment settings (obviously the front struts moved to track position). I rotate left/right after day1 at track and get extremely good/even wear all around. (I do measure each tire from new to current with a decent Longacre Depth Gauge, and so far very happy). I like these 3Rs like SportCups I've had before. (OK I guess 9/10ths as much). Start at 29 cold reaching 35/36max hot.
BobR
2018 ZL1 1LE (Red) - New Dec 2017
2015 ViperGT (Gunmetal w/Red stripes)
2013 ZR1 Anniversary
2014 ZL1 - BrightYellow, 6sp
2011 Porsche GT3RS - White w/red graphics
2009 Porsche C2S
2001 Ferrari 360
kaamacat is offline   Reply With Quote
Old 09-29-2019, 07:51 PM   #18
vr46
vr46's Avatar
Drives: 2019 ZL1 1LE
Do you guys know if you can flip the EF1's? I'm on street setting currently, so outsides are wearing quicker but inner half still looks good. If I can flip the tire around, I can get probably two more track days.
vr46 is offline   Reply With Quote
Old 09-29-2019, 09:23 PM   #19
Try2paz
Drives: 1967 Nova
In my opinion that would be a downgrade. Driven on both tires in a back to back session. The Eagle F1 Supercar 3R is definitely a better tire on track.
Agree I’ve done back to back and the cup 2’s are not as good. I’m running g cup 2’s right now due to availability of the Goodyear’s.
Try2paz is offline   Reply With Quote
Old 09-30-2019, 12:13 PM   #20
SWZL11LE
SWZL11LE's Avatar
Drives: '19 ZL1 1LE
I would first look at your toe settings in the front to see if they are still good.
Some tips to improve front tire life would be to try taking different lines on the corners that are putting a lot of load in the front tires. "Square" off some of these corners if possible, it might even be a faster line than you are currently taking with the car.
Just like you I've had pretty even wear on front and rears. I do rotate left to right after each day. Only time I corded inside of the fronts was due to the toe being off in the front. I run around 31 to 33 psi max on hot pressures.
Old 09-30-2019, 05:12 PM   #21
s.hammer
Drives: 2015 Z/28
It was way easier to switch my tire to the NT-01r than change my driving style, lol
Old 10-02-2019, 09:55 AM   #22
wnyzl11le
wnyzl11le's Avatar
Drives: 2019 zl1 1le
Originally Posted by vr46 View Post
Hi...I read alot of older threads on tire options along with wheel sizes (some going to 18's for example). Just looking to see if there is any current info on best 19's for track use, while keeping affordability in mind.
I recently picked up a 2019 ZL1 1LE as a dedicated track day toy and plan to keep it stock. The EF1R's are performing well but just curious to learn if members found more affordable options then simply buying off TireRack for example. Any group buys that I'm not aware of?
Are members moving away for EF1R's to Cup 2's for example?
(Or other brands?)
Thanks for any insight.
Sorry it took me so long I forgot to look up the pricing.
$266.99 for fronts 305/30/19 and 305.99 325/30/19 Supercar 3R at my local good year. I have a copy of the quote sheet the guy gave me. DM and I will pass it along.
2018 GMC Denali 6.2L
2019 Camaro ZL1 1LE 6 speed Riverside Blue 1LE NAV PDR. PPF entire car
wnyzl11le is offline   Reply With Quote
Old 10-02-2019, 02:32 PM   #23
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Yes you can flip them, I flipped my SC3Rs and it really helped extend life. Having a tire shop at the track makes this much easier.
SFV1LE is offline   Reply With Quote
