Old 09-08-2019, 09:42 PM   #15
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
I used one of these:
https://www.amazon.com/gp/product/B0162BSK0M
I cut off some of the top to make like roof shape, so they were easier to place on rear most front lifting point.. get to both wheels using one jack placement.
ing for grip.
http://www.motorsportsne.com/
Old 09-09-2019, 12:10 AM   #16
HighIron
Drives: 2024 2SS Summit White
Originally Posted by Zaqwert6 View Post
1 set = 4 pads
Very good. So noted...just ordered a set.
Thanks
HighIron is offline   Reply With Quote
Old 09-09-2019, 01:10 PM   #17
Zaqwert6
Zaqwert6's Avatar
Drives: 2SS
Just keep an eye on them, overtime / with use, I've seen those tear in half down the center.
Zaqwert6 is offline   Reply With Quote
Old 09-09-2019, 01:20 PM   #18
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Mine a bit chewed up already from sometimes missing the slot, chamfering the top helped, since its easier to place. It just about sits flush w lower surface of skirt on ZLE.
Just for this year, wheels will get swapped out 20 times. Another 2 once snows go on.
ing for grip.
Old 09-09-2019, 05:16 PM   #19
mrzab
Drives: 2018 Red Hot ZL-1
Guys, Retmil let me know he wants the jack pads so they'll be going to him. Sorry I couldn't help all of you out.
mrzab is offline   Reply With Quote
Old 09-09-2019, 05:46 PM   #20
camaroJD
Drives: 2019 Satin Steel 1SS 1LE w/ PDR
Thanks anyway.
If anyone wants to split a set of four or sell me two pads, PM me.
camaroJD is offline   Reply With Quote
Old 09-09-2019, 10:09 PM   #21
oslouie
oslouie's Avatar
Drives: 2018 2SS M6 Redline
Originally Posted by camaroJD View Post
Necessary enough that I'm looking for two more. I really hate using the magnet/puck to jack up the car. It feels dangerous and unstable.
Where will the other two go?
oslouie is offline   Reply With Quote
Old 09-10-2019, 11:54 AM   #22
grampa_ss
grampa_ss's Avatar
There's 2 open sections towards the front.
Old 09-10-2019, 06:26 PM   #23
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
You use the rearmost front ones to jack the car and set your jack stands under the front and rear ones, the chassis is so stiff both wheels come off the ground. Let me cost you guys some money, these stands are tier one and the cradles fit the pads like a glove, they also won't sink into your asphalt driveway like conventional stands.
https://www.amazon.com/Torin-Big-Alu...ateway&sr=8-14
Warrior102 is offline   Reply With Quote
Old 09-10-2019, 09:29 PM   #24
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Yeah those are pricy-fancy. Like these:
https://www.tooltopia.com/esco-10498...RoCjrcQAvD_BwE
if you want to spend >$100/pair and look good doing it.
But a scrap of 1/2” plywood or mdf always worked well for me under a $20 set of Craftsman stands on softer surfaces.
With the vert you end up putting the stand under the xbrace bracket anyway. The lift points are really only used for jacking. And the concave cup on my trolley jack fits the ZL1 Addons lift points perfectly.
Old 09-11-2019, 06:54 PM   #25
Magnum922
Magnum922's Avatar
Drives: 2017 Camaro 2SS, A8
Anyone use these kind?
Magnum922 is offline   Reply With Quote
Old 09-11-2019, 10:09 PM   #26
LARRY01Z28
Drives: 2001Camaro Z28
thanks for the info
LARRY01Z28 is offline   Reply With Quote
