Old 08-25-2019, 05:58 PM   #15
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
is that possible or is this self imposed?
gotswap is offline   Reply With Quote
Old 08-25-2019, 10:07 PM   #16
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
See images from 2018 Helms manual.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 08-26-2019, 11:44 AM   #17
travislambert
Drives: '17 ZL1
Originally Posted by angryBits View Post
However, when I drive straight, the steering wheel is visibly slightly turned to the right but that's because I mounted the steering wheel 1 tooth off from the original center on the shaft.
I don't believe this is possible. The steering shaft is keyed with the wheel. It will only go on in one position.
I'm wondering if the wheel itself may have had the key location in a slightly different orientation. If this is the case, you'll need an alignment and a calibration of the steering angle sensor.
travislambert is offline   Reply With Quote
Old 08-26-2019, 11:51 AM   #18
ABQautoxer
ABQautoxer's Avatar
Drives: 2019 ZL1
This was one of the two possibilities I was trying to explain, you worded it much better.
ABQautoxer is offline   Reply With Quote
