Old 08-23-2019, 09:45 PM   #15
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
why does the SS 1LE have the ZL1 pump?
Old 08-24-2019, 09:41 AM   #16
6spdhyperblue
Drives: 2SS 1LE
What is the trade off on the bigger fuel lobe? 100rwhp is significant enough to think there’s a catch
Reduce life on the lt1 pump? Uses more hp to run over a LT4 pump?
Old 08-24-2019, 05:59 PM   #17
parbreak
Drives: 2017 50th Camaro SS
Originally Posted by JCunningham View Post
is it illegal if i pay a hooker to do it.
Not in Nevada
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 08-29-2019, 02:03 PM   #18
JCunningham
Drives: 2017 2SS M6
got it in wasnt to bad.
Old 08-29-2019, 02:19 PM   #19
6spdhyperblue
Drives: 2SS 1LE
You dropped the tank right
Old 08-29-2019, 02:49 PM   #20
grampa_ss
grampa_ss's Avatar
Bumping, as this is a good question.
Old 08-29-2019, 03:00 PM   #21
oldman
Drives: SS 6 speed of course
I'm sure with anything mechanical there is a reduce life with a longer stroke.. like 1.2 mm or sumting?? I'm sure the longer stroke takes more HP to run, Just like twin valve springs x 16. I can't be too tuff as the roller lifter is just a tad bigger than a valve lifter.
Old 08-29-2019, 03:10 PM   #22
JCunningham
Drives: 2017 2SS M6
yes dropped the tank easy did it by myself and didnt even have to crack a diff cooler line. doing shifter and cradle bushings.
Old 08-29-2019, 03:16 PM   #23
6spdhyperblue
Drives: 2SS 1LE
Yeah I think that’s a good trio for this job. Pump, shifter, cradle bushings. Three birds one stone Nice!
Old 09-01-2019, 03:34 AM   #24
JCunningham
Drives: 2017 2SS M6
should the voltages be changed. i noticed the ZL1 is 15.5v?
Old 09-01-2019, 03:36 AM   #25
JCunningham
Drives: 2017 2SS M6
I did AC Delco M100183 for the LT4 in-tank pump. Hopefully I did the right one...lol
You’ll also want to change the desired fuel pressure in the FSCM. Will cost you one credit with HP Tuners.
you talking about post #2 https://www.camaro6.com/forums/showt...=zl1+fuel+pump
Old 09-01-2019, 07:22 AM   #26
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Yes, that table plus the voltage table you listed above are what I was referring to.
Old 09-01-2019, 01:32 PM   #27
JCunningham
Drives: 2017 2SS M6
cool ill change it thanks
Old 09-01-2019, 03:22 PM   #28
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Yep that table needs changed. I have even seen some use 16.5 volts.
