Old 06-02-2019, 07:57 PM   #15
Jason18ZL1LE
Drives: 2018 ZL1 1LE
I’d be disappointed. I put down 640whp with 91 on a 105F+ day on a Mustang dyno. My mod list is below. On E85 I’m well over 700 and still stock blower and TB, no porting.
2018 ZL1 1LE - Summit White
529whp Baseline / 760whp 762tq
ARH Ceramic Coated LTH 1 7/8" \ ATI 15% Lower \ RotoFab Big Gulp \ Katech 103mm TB \ Ported Blower \ DSX Fuel System \ Flex Fuel E85 \ Custom Cam \ Dual Springs \ Corsa Exhaust \ Prospeed Heat Exchanger \ Cordes Big3\ C&R Racing Radiator \ LS3 Stat housing \ 160* Thermostat \ NX Lid
Jason18ZL1LE is offline   Reply With Quote
Old 06-02-2019, 09:21 PM   #16
GT-ER
Drives: 2018 Camaro ZL1
Originally Posted by F419sr1 View Post
Mine did 665 on 93 no meth. Stock cam kooks with green cats roto fab and a 103 Tb. 13 pounds of boost. On e40 it made 698 and was running out of fuel. I also have the booster. My tq is no where near yours. 639
What dyno type?
You have a cam though, which makes a huge difference. I would expect a whipple stock cam car to be similar to a stock eaton but cammed car.
Also, doesn't a dyno dynamics read even lower than a mustang?
Either way, I'm not going to dwell on this. I'll just try it on some other dyno's to see what happens. Ultimately, my fault for not getting a baseline before I modded and I suppose that, ultimately, dyno numbers don't really matter at the end of the day.
GT-ER is offline   Reply With Quote
Old 06-03-2019, 07:03 AM   #17
Markoz28
Drives: 18 ZL1 nightfall grey A10
I think the best way to measure if what has been done works is to take to the drag strip. A baseline pass would have been good but if you can run now in the low 10s (good tires needed) then you should be good. I would think.
Bone stock I ran 11.4 at 120mph stock tires with 3k miles. I added RF intake, 2” kooks, 9.1 pulley and MS tune and ran 11.3 at 129mph stock tires with 9k miles. Time difference was not much better but mph was awesome! Plus first time out was in 60 degree weather and 2nd time out was in 90degree with humidity of 75%.
Markoz28 is offline   Reply With Quote
Old 06-03-2019, 08:45 AM   #18
mexi
Drives: 2017 ZL1
car needs a cam
2017 ZL1 Hyper blue. Heads cam headers meth built by TKperformance.
mexi is offline   Reply With Quote
Old 06-03-2019, 10:24 PM   #19
GT-ER
I'm dying to go, it's my lack of time that really kills me since the closest track to me is over an hour away. I have R888R tires out back so I should be okay traction wise.
Old 06-04-2019, 07:55 AM   #20
Markoz28
I’m getting those same tires in 4 weeks. Closest drag strip to me is an hour away as well. I have to plan it accordingly. I won’t be going again until fall, sometime around October to get some better air. With that and some good tires hoping to cut a 10.8 pass. After that I’m debating on porting the SC and e85 or meth, or saving for a much longer time and going Mag 2.3 and e85. I would love to do a cam but I need the car to act like stock “per request/demand from the wife.”
Old 06-04-2019, 09:40 AM   #21
staples87
Drives: 2017 Camaro ZL1
640 / 710 as long as the Dyno Dynamics wasn't altered to read Dynojet numbers would be around 680-690whp and 740-750rwtq on a DJ. That's pretty solid numbers in my opinion. You may want to check and see if it's pulling timing up-top or if it's a very conservative tune and could use a degree or two in the upper range.
You could also check the vacuum on the car under wide open throttle, that will give you an idea on your intake restriction. If there is a lot of vacuum at wide open, that could indicated an air flow restriction (throttle body or air intake).
'17 Camaro ZL1 M6
staples87 is offline   Reply With Quote
Old 06-04-2019, 10:32 AM   #22
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
Where would you check vacuum @ WOT? Anything WOT is under boost, any amount of vacuum would be a massive reduction in power
gotswap is offline   Reply With Quote
Old 06-04-2019, 12:28 PM   #23
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Intake tract is never under boost, so I'm assuming that's what he was referring to.
Old 06-04-2019, 02:33 PM   #24
GT-ER
Timing is 20-21* all the way to redline, 0 KR. I'm sure I can add another degree or so of timing but don't know what it'll be worth when I'm already over 20* and at 16-17psi. Boost also doesn't fall off in the upper rpms, on the contrary, it climbs all the way to redline.
Larger TB does make me think though...good call on the vacuum readings. That's a cool and somewhat easy test to do.
Old 06-05-2019, 09:36 AM   #25
staples87
Correct. I should have clarified.
'17 Camaro ZL1 M6
Old 06-05-2019, 09:59 AM   #26
7WSM
7WSM's Avatar
Drives: 2017 ZL1 A10
The AF looks to be a little rich. Most of the guys I know that do DI cars run it a little close to 12.5-13.
7WSM is offline   Reply With Quote
Old 06-05-2019, 10:04 AM   #27
GT-ER
13 is pretty lean, I ran 12.0 before the meth but wanted to run a little richer with meth in case it failed my engine has a chance. Either way, AF ratio doesn't affect power too much unless it's pig rich or crazy lean.
Old 06-05-2019, 10:45 AM   #28
staples87
Yeah that's plenty of timing for 16-17psi, so that's good you're not getting any knock retard. If you have HP Tuners and can log, I would enable MAP in kPA and do a log. Keep an eye on wide open throttle to see if the number starts to drop off, especially in the higher RPMs. That would tell you that the engine is struggling to breath in the upper range. This would be a simple way of trying to figure out.
'17 Camaro ZL1 M6
