Old 04-30-2019, 09:35 PM   #15
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
It should be noted that the NLS feature was only added on the 17+ models for the LTG.
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 04-30-2019, 09:49 PM   #16
zts1986
Drives: 2019 Chevrolet Camaro 1LT 2.0T
I have a ‘19, so I’m good to go. Now if only I had launch control...
zts1986 is offline   Reply With Quote
Old 04-30-2019, 10:26 PM   #17
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
What's strange is, people are reporting that their 2016 does have it. I know mine does. Not sure why some wouldn't have that feature. It's the exact same part# transmission as the 17'+ model years.
*Side note, I have all of the software updates that have come out for the car. Not sure if NLS was part of any of those updates??? Just a thought...
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 05-01-2019, 05:28 PM   #18
wookwook
wookwook's Avatar
Drives: 18 Camaro LS M6
eeeh, What software update? I tried NLS today and it didn't work. It could be I need to really make sure about the press of the gas to the floor, but if its that finicky I guess its just not that compelling to me. I am only slipping the clutch enough to know its revving up. What they are saying is true, its a mind game, lol.
back to the original topic, the 1-2 shift rev has settled down. Can only offer it must have been an adaptive thing since I had just re-zeroed the ecu (put the race-chip loopback adapter on for a few cycles) after replacing my MAF sensor. I'm also running the XLR.
wookwook is offline   Reply With Quote
Old 05-02-2019, 10:51 AM   #19
Adp2017
Adp2017's Avatar
Drives: 2017 RS Turbo
you need to be at 95% throttle to be able to use the NLS as far I know or can remember
2017 1LT | RS | 2.0T | M6
331 rwhp , 350 rwtq
ZZP Intercooler | ZZP Catted DP | Magnaflow Catback | Injen CAI | Tuned (BBR) | CNC Honed Turbo (TPC) w 14lb actuator
Adp2017 is offline   Reply With Quote
Old 05-02-2019, 05:08 PM   #20
wookwook
wookwook's Avatar
Okay I got it to work and it scared the sh*t out of me. It sounds like a jake brake, but it works. The trick to it was stay in low gear and slowly get close to the 4500 mark, then go to WOT and then it is easier to experience. Second time I let off the gas and it like returned to rev up again. It will take some practice. and clear roads. and no cops.
Old 05-03-2019, 01:17 AM   #21
Start The Machine
Going 3rd to 4th is the easiest way to try it out.
Old 05-08-2019, 06:09 AM   #22
Migs19
Migs19's Avatar
Drives: 2019 Crush Camaro
tried NLS
I tried out NLS 0-60 yesterday. It worked as advertised, but my times were terribly slow. I'm new at this so I need lots of practice. Nannies were on so I will try with TC off next time. All stock '19 LS mn6.
cheers, Mig
Migs19 is offline   Reply With Quote
