Old 05-20-2019, 06:40 PM   #15
parish8
Drives: 17 SS a8
No meth, just a big air to air. I am doing an “interchiller” set up that uses the ac to chill the fluid so no ice. I do not expect this intake to make me much if any faster. I think the car as it sits now would take me well into the 8’s. I have always just wanted to try an interchiller and this intake will make the most of one.
Old 05-26-2020, 01:23 PM   #16
parish8
Drives: 17 SS a8
I finally got around to working on my car again and have some data. I will have lots of data eventually.
I opted for the stage 2 interchiller set up which gets you a 2nd condenser and supposedly temps down near 0deg. Unfortunately it isn’t working out quite that well. After doing a fair amount of reading it seems our style of compressor is limited as to how much suction it can pull. Suction = low pressure = low temp.
What am happy about and what the stage 2 kit is likely helping with a little is how quickly it chills the fluid. This thing takes 5-6gallons is fluid and drops it from 72deg down to 30deg in 15minutes flat. 😳
I will be logging everything under the sun once I get it driving and have more data like air temps.
Old 06-02-2020, 02:37 PM   #17
parish8
Drives: 17 SS a8
I insulated everything and gained about 1/2 a deg. I thought it would be more. Then i pulled a trick with the freon and gained about 6 deg. This is all in the garage. Once I get out on the street it might do better.
Old 06-02-2020, 07:10 PM   #18
laynlo15
Drives: 2022 Lt1 A10
Parish where the hell have you been?
Old 06-05-2020, 09:13 AM   #19
parish8
Drives: 17 SS a8
I dropped a valve last year and messed up my motor. I decided to take a break from the car and pay some stuff off. I am back to spending money again but am kind of leaning toward building a more showy car/dyno queen/ street car and eventually building a separate dedicated light weight drag car. I am trying to remember to enjoy the building of the car.
Old 06-05-2020, 09:14 AM   #20
parish8
Drives: 17 SS a8
Hell yeah
Old 06-05-2020, 09:29 AM   #21
Umbriel
Drives: 2016 Camaro SS
This what I always do with my cars, I have no desire to do a track only all out build. I want something that looks good, can be driven anytime I want anywhere I want but has the power to kill most things you run into on the street. I am doing a 416 twin turbo build shooting for 1200 rwhp, that should be plenty and it will still look and drive like factory mostly.
Umbriel is offline   Reply With Quote
Old 06-05-2020, 09:42 AM   #22
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Hell yeah
Looks nasty, Parish!
Old 06-05-2020, 01:48 PM   #23
laynlo15
Woosh, its gone.
Old 06-18-2020, 03:17 PM   #24
parish8
Drives: 17 SS a8
I should have some low boost data soon. It is running and driving.
Old 06-19-2020, 12:07 AM   #25
toohighpsi
Drives: 2015 C7 Z06 M7
Looks awesome Parish!
Old 06-19-2020, 08:31 AM   #26
95 imp
Dumb Ass Deluxe
Old 06-20-2020, 08:28 AM   #27
laynlo15
Looks very wicked and I'm sure it will run that way also. Tracks are starting to open so get prepared to do some test and tuning.
Old 06-23-2020, 07:59 PM   #28
parish8
Drives: 17 SS a8
got some data. this is some neat stuff if you like data. note the air temps in the 3rd section. this is a stock genV 5.3. car made 533rwhp on a mustang dyno which seems about right for a stock 5.3
I also logged pre turbo exhaust pressure and it was an exact 1-1 ratio with boost. that isn't in this pic.
