#15 |
Stop by our site and shop around. We have tons of NPP upgrade options. A few top sellers would be Flowmaster, Stainless Works, B&B, and Borla.
On a side note, if you like the way the stock exhaust sounds but just want it louder/exaggerated a set of long tube headers might be exactly what you are looking for. Long tubes will add volume and legit horsepower. If you order a set like Stainless Works that connects at the rear muffler you will remove all the factory 2.75" piping and the crush pipe( it becomes restrictive when you start adding power). When you're ready to order hit us up or use code CAMARO6 and save some cash. |
#16 |
![]() Drives: 2015 ZL1 Join Date: Jan 2015
Scary, if you are still weighing out the options, we would recommend our Race Series axle back if you were looking for something more on the aggressive side. It's essentially a muffler delete, so it saves some weight while still retaining the NPP feature. If you'd like to check it out further, you can find it here on our website:
https://www.magnaflow.com/products/1...s?aces=5927642 Let us know if you have any questions! |
#17 |
![]() Drives: '16 Red Hot 2SS M6 NPP Join Date: Apr 2016
Sorry Magnaflow, but your Race series retains NPP function for no reason at all as closed or open is the same sound with possibly a a flow/performance decrease when closed. The product makes no sense. Your other products make more sense to me.
With that said, OP, I have the Borla Atak with secondary cat delete and its amazing. The stealth mode is definitely quieter at higher revs. Open is thrilling. Mine is 2.75". It was worth the money.
![]() '16 2SS, M6, Borla Atak |
#18 | |
![]() Drives: 2017 1LE Join Date: Nov 2017
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube |
