Old 02-14-2019, 07:13 AM   #15
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
I had one for 2 weeks and sent it back to Range because the transmission kept going in and out of trying to lock up the convertor. Removed it and all is good. I know it works for some but it did not for me so I got my money back. I have an extended warranty and will let GM worry about the shudder. Eventually they will get tired of seeing me
dmcmahan60 is offline   Reply With Quote
Old 02-14-2019, 09:06 AM   #16
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
I also have the Range unit and no issues but still had the "fart" on startup until I pulled fuse 51 which leaves the exhaust open on NPP units. I will also add I like the sound much better after pulling the fuse.
craigss50 is offline   Reply With Quote
Old 02-14-2019, 10:06 AM   #17
rich6111
rich6111's Avatar
Drives: 2018 2SS Mosaic Black Metalic
what is npp unit. i have a 18 ss 6.4 4 pipes
rich6111 is offline   Reply With Quote
Old 02-14-2019, 10:30 AM   #18
rich6111
rich6111's Avatar
new fix for shudder is tsb 18-na-355. sounds like it works. doing mine2/19/19.
Old 02-14-2019, 10:40 AM   #19
SSport16
SSport16's Avatar
I use a Range all the time now. It does help with the shudder greatly. I have tried both with and without, my car is terrible not using the Range. I am taking mine in soon to have the new flush done, hoping with that and the Range it will be good for a long time...we shall see.
Old 02-14-2019, 08:34 PM   #20
GroundhogSS
GroundhogSS's Avatar
You most likely have it. GM has an optional performance exhaust with four pipes but I've never seen anyone with it. The multi-mode exhaust has valves on the pipes to route more or less gas through the muffler, depending on driving mode set and throttle setting. If you have a fuse in the F51 spot in the fuse box under the hood, try pulling it out. You should hear a difference. The valves stay open.
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 02-15-2019, 06:29 AM   #21
craigss50
craigss50's Avatar
Yes, NPP is the GM code for Bi-modal exhaust or performance exhaust which has adjustable sound modes and has 4 exhaust pipe tips.
Old 02-15-2019, 04:31 PM   #22
Mgsouthwest2001
Mgsouthwest2001's Avatar
Drives: 18 Camaro 2SS 8A Hyper Blue
Just got my Range two days ago. Installed it and love it. Works perfectly with no problems whatsoever.
18 Camaro 2SS: Hyper Blue 8A
Mgsouthwest2001 is offline   Reply With Quote
Old 02-15-2019, 05:36 PM   #23
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Originally Posted by Soleil View Post
The range has nothing to do with the shudder.
It should, AFM mode screws around with the torque converter operation and the Range unit stops AFM activation.
lt4camaro is offline   Reply With Quote
Old 02-25-2019, 03:42 PM   #24
rich6111
rich6111's Avatar
got range today and it works great,so much better. it is 8.6 version. man date is 1/17/2019. ebay for total of $160. will use adpter w/switch to turn on and off if needed. range said 8.6 don't draw power with engine off.
Old 06-29-2019, 10:54 AM   #25
Marco Falcone
Marco Falcone's Avatar
Drives: 2018 2SS Convertible MBM/Kal
Update: Had the Range for just over a year and approx 13,000 miles.
Zero issues. No CEL’s, no A8 shudder, etc. Works great.
Also, left it plugged in while the car sat for 15 days while I was on vacation. Started right up like “normal.”
Excellent device.
2018 2SS Vert. MBM/Kalahari. MRR FS01’s with 285/305 MPS4S. Black Bow ties, A8, MRC, NPP, 6-piston Brembo’s w/ matching rears, OEM Ground Effects/Splash Guards, 8”/Nav. Borla S-type, Pray IM/TB, RotoFab.
Past DD’s of note:
2013 Caprice PPV. (“Company” car.)
1998 Cadillac STS
1996 Impala SS
1969 Cadillac DeVille Convertible
1993 Corvette
1991 Mustang 5.0 LX
1973 Alfa Romeo Spider
1986 Mustang GT T-top
1964 Falcon Sprint Hardtop. (First car, still have the key!)
Marco Falcone is offline   Reply With Quote
Old 06-30-2019, 06:56 AM   #26
mdhopt36
Drives: '17- 1ag37 V6 traded, for 1SS 2018!
I have run the Range for several weeks now. When car is shut off, there is an LED on it that is still on- so mine -DOES- draw power; and the instructions said to unplug it if it's gonna set for several days or longer.
I just bought an extension with switch in line, that works very well also- just slung it over the steering column, and switch is right on top.
Car doesn't get 30~mpg now, it's down at about 26-27. But so what? No more exhaust fart, or lag. And no vibration or shudder from tranny either.
mdhopt36 is offline   Reply With Quote
Old 09-21-2019, 09:41 AM   #27
caSStro18
Drives: 2018 Camaro SS
Does the module stick out very far? Is it in the way of getting in and out of the car? Also, will it do any harm to the afm system being disabled all of the time?
caSStro18 is offline   Reply With Quote
Old 09-21-2019, 09:43 AM   #28
SSport16
SSport16's Avatar
No and no...I use mine all the time, just don't leave it plugged it for an extended number of days if the car sits without being driven, it still draws power when the car is turned off. I have a switch on mine.
