Old 02-13-2019, 03:19 PM   #15
Zzsteve
Zzsteve's Avatar
Drives: 2018 2SS
doing a little more digging on this, the 2018 uses an "E80-A" ECM, where the 16 and 17 use an "E80" which is likely the difference. the flex has likely always worked once wired/enabled on the 18 models. GM did this same thing with the LHU ECU's a few years back. (and the chevy cruze....flex doesnt work on the 11, but does on 12+even though its the 'same')
we actually have an 18 ATS here which shares the same part number ECM as the 18 Camaro. im going to try to get that in tomorrow or friday to test the theory that its an 18+ or "e80-a" fix currently. if it is, ill look into swapping the 80-A core into our 17 (if its even feasible). and if that goes well, the 18 core may just be the fix for the 16-17 models!
thanks to the OP for trying this on an 18 model! if this is the fix, this will be HUGE for this community!
Zzsteve is offline   Reply With Quote
Old 02-13-2019, 03:43 PM   #16
raflyer
Drives: 2014 Cadillac ATS 2.0T
This means you guys need to get some HPFP's on the market as well as the high volume LPFP's. Throw in some higher flow inj's as well. hehe
raflyer is offline   Reply With Quote
Old 02-13-2019, 05:17 PM   #17
turbojeep95
turbojeep95's Avatar
Drives: 17 Camaro lt, 22 Camaro LT1
Nice work Coop! That's a heck of a contribution to the ltg camaro forum!
turbojeep95 is offline   Reply With Quote
Old 02-13-2019, 07:23 PM   #18
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
aka huge for your wallet.
Old 02-13-2019, 09:15 PM   #19
Zzsteve
Zzsteve's Avatar
Drives: 2018 2SS
Side effects may incluuuuudeeeee.
Seriously tho. The ability to run flex is going to push a LOT of people into more serious builds. Times will get faster. People will get more competitive within, and outside of this market. It will promote innovation and competition, which is ultimately awesome for everybody involved!
Old 02-13-2019, 09:58 PM   #20
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
I know exactly what your next development product to the table needs to be. You know if your serious when you say you want advance the platform into bigger more progressed builds.
A8 Converter ya do that we will buy if you make.
Old 02-14-2019, 07:02 AM   #21
whiskeyfed
Pat
whiskeyfed's Avatar
Drives: 2017 Camaro 1LT I4 Turbo A8
I'd love to see this come to fruition in any way. e85 is so scarce in my state that I would have no choice but to use a flexfuel option.
Coop, keep up the hard work dawg!
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro
Follow my Build Thread The WhiskeyFed Camaro
Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket
DYNO SHEET: 297whp / 374wtq
Tuned by #danytechtuning
whiskeyfed is offline   Reply With Quote
Old 02-14-2019, 09:01 AM   #22
Jason@JacFab
2017 uses the E80a also.....
Old 02-14-2019, 03:11 PM   #23
Zzsteve
Zzsteve's Avatar
Drives: 2018 2SS
Just installed our flex kit on an '18, and it works perfectly.
we have had the kit installed the exact same way on a 16 and 17 since last year, and neither work. i took apart the 17 today to double check all of my wiring, and its all correct, it just flat out doesnt do what its told :(
Old 02-14-2019, 04:39 PM   #24
DarkFangz1100
Drives: 2016 Camaro SS
So what are you gonna do to remedy this situation? I need it in my life
DarkFangz1100 is offline   Reply With Quote
Old 02-14-2019, 06:55 PM   #25
Johnny2343
Drives: 16 1SS 6mn npp
Have you tried any other 17’s other than shop car??
Johnny2343 is offline   Reply With Quote
Old 02-15-2019, 08:21 AM   #26
Zzsteve
Zzsteve's Avatar
Drives: 2018 2SS
i have not personally installed on a 'different car' but we have had a couple in here with brand 'R' kit on it (came in with it) same thing. i did fully remove, and re-install the kit on our 17 as a double check.
Old 02-17-2019, 07:59 AM   #27
turbojeep95
Dumb question but do you have to tune for all the different levels of ethanol or can you do a few different percentages and have the tuning software ramp it?
Old 02-17-2019, 08:11 AM   #28
raflyer
Fuel trims look good, HPFP good Question, why does advance say -3.5 in the table but +6 in the gauge screen?
Wait till you start putting timing into that e85 likes
