#15 |
Mike
Drives: 2018 1SS 1LE Join Date: Nov 2014
#16 |
#17 |
![]() ![]() Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
That is what the warranty is for. If anything he should run it hard a lot in the first 5 years because it's covered if it does blow. 1LEs are made for track use.
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
#18 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Chevy tracks the performance variants nearly to the level of the Corvette. If you understand what’s all involved... The car will be just fine on track. The V6 and Turbo 1LE were track tested like the SS 1LE. |
#19 |
![]() Drives: Silverado Join Date: Nov 2018
My thoughts exactly. Chevy wouldn’t market this as a track ready variant if it was going to blow up. It’ll be just fine.
#20 |
![]() Drives: 2024 ZL1 M6 Nitro Yellow Join Date: Apr 2019
I thought I read on here that a Turbo 1LE just won Cam C class last fall against the v8 cars? Seems like it did alright on the track...
#21 |
![]() Drives: 2017 SS 1LE Join Date: Jan 2018
That was autocross not a track, completely different. But either way it should be fine on the track, I mean it has been tested to work on the track so I don't see why it wouldn't be fine.
#22 |
![]() ![]() Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
Shoot, I'm planning on taking my non-1LE turbo 4 to the track. I'm going to push it to see how far it can go. I'll eventually do brakes and cooling upgrades. But am I concerned about even the stock model? Nope. The radiator and intercooler are fairly high capacity for this engine and the turbo 4 camaro is really light. Mine is 3280 pounds. I won't be doing a lot of lead foot braking around a small road coarse in this car and I won't be going 10/10 before doing brakes/fluid and maybe an oil cooler, but I have no doubt that this car bone stock will make it around the track at 7/10 and not have a problem.
With the auxiliary coolers on the turbo 1LE, its not even a question. It can handle being pushed hard 10/10 on the track with no mods. Someone made a comment about the Corvette. It's interesting, the corvette C7 forums are absolutely littered with discussion about over-heating problems, even on supposed track variants, Z06, grand sport, etc. I've been on Camaro6 for some time, and I can count on one hand the number of threads about over-heating in a 6th gen camaro. Several times it seemed to be an electrical issue with the fans not coming on. I've never heard of a single turbo 4 ever over-heating, and its not because people aren't driving these cars hard. The only conclusion I can come to is that GM really did a good job with heat management in this car. There are a few aftermarket parts that claim more capacity but the OEM system is very good. Last edited by protovack; 04-16-2019 at 04:22 AM. |
#23 |
I should have clarified, I will be doing autocross, not track racing.
#24 | |
![]() Drives: 2018 1LS 1LE Join Date: Jan 2018
A guy I know bought one and is using it for time trials (NASA, GTA, Grid Life, etc). He owns a performance shop here in the ATL-ish area. Follow him at https://www.facebook.com/2JRacing-206550699368164/ and https://www.instagram.com/2jracing/
It does include the 'extra capacity' cooling system so that should help with road course duty.
#25 | |
Camaro Turbo and V6 1LE Turbo 1LE features a 2.0L engine rated at 275 hp and 295 lb.-ft. of torque, matched with a 6-speed manual transmission V6 1LE features a 3.6L engine rated at 335 hp, matched with a 6-speed manual transmission FE3 suspension components (from the Camaro SS), including dampers, rear cradle mounts, ball-jointed rear toe links and stabilizer bars Lightweight 20-inch forged-aluminum wheels paired with Goodyear Eagle F1 245/40R20 front and 275/35R20 rear summer-only tires† Brembo 4-piston front brake calipers Mechanical limited-slip differential with 3.27 ratio Standard track cooling package with engine oil, differential and transmission coolers Suede steering wheel and shorter-throw shifter Dual-mode exhaust system (V6 models only) Camaro SS fuel system for higher-load cornering capability Satin black hood, front splitter and unique 3-piece rear spoiler Unique high-flow mesh upper and lower grille with satin black accents Available RECARO® seats Available Performance Data Recorder |
#26 |
![]() Drives: 2017 Chevrolet Camaro 2.0 LT Join Date: Apr 2017
I see heavy duty cooling package, and extra capacity cooling listed with the 1le options on the chevy build site. I know on 16-18 it added an oil cooler and the aux radiators.
#27 | |
Here's the link to the pic I'm referring to: https://www.instagram.com/p/BsZOknkgMDX/
#28 |
Unless I'm interpreting their codes incorrectly, extra capacity heavy duty cooling (RPO V03) and auxiliary coolers (RPO V18) are 2 different things.
