Old 02-02-2019, 06:53 PM   #15
WEAPON-X
WEAPON-X's Avatar
Drives: ZL1 ATS-V CTS-V C7Z Range Sport SC
Originally Posted by BOWTIEBOB View Post
I have the 2019 ZR1 ZTK with the high wing. The 900 plus pounds of down force reaches max at or near top speed as I understand it 200 plus mph. Would like to see 155 mph comparison to learn actual increase in down force. On the ZR1 it is "front balanced" with an underwing to prevent the lift and instability that can accompany that much down force. Furthermore, the ZTK wing is mounted with hardwar to the frame with metal brackets. Weapon X uses billet for his ZR1 brackets but I don't know if factory trunk mount brackets would be strong enough for that much down force. I have a 2017 ZL1 and would have to determine the instability and steering response to so much down force on the rear. Weapon X quality and engineering is second to none however I would like to see some data on durability, handling and other factors affecting safety before mounting this laege wing on the trunk of my ZL1.
The total downforce of the entire car is 900lbs, not just the wing
Originally Posted by angryBits View Post
I hate to be the nay-sayer but I don't think this is going to be a performance improvement, only cosmetic. It may even hinder performance compared to the OEM ZL1 1LE wing.
GM already went ludicrous-mode on the ZL1 1LE, including its wing. If the ZR1's wing was going to improve performance I sure they would have used it.
I'd bet the ZL1 1LE's wing is the exact balance of downforce and drag to reach optimal lap times.
My guess would be that the ZR1 wing is going to hurt lap times and certainly hurt 0-60 and 1/4 mile times if you're into that.
Having said all that -- there's nothing wrong with modding purely for cosmetic reasons
Just putting it out there.
ZR1 came out a littttttle later than the ZL1 1LE
WEAPON-X is offline   Reply With Quote
Old 02-02-2019, 09:06 PM   #16
Intimidator
Drives: 69 GTO, 05 GTO, 2018 Silver ZL1
Keep us posted Ben...I want a beefier rear wing with medium stanchions, but I still can't picture the ZR1 wing on the ZL1, in my mind!
Intimidator is offline   Reply With Quote
Old 02-02-2019, 09:37 PM   #17
angryBits
angryBits's Avatar
Drives: ZL1 1LE A10
Their development timelines overlapped quite a bit.
If there was an opportunity to share a part between them, that would have happened.
No doubt the wing research teams collaborated since they're similar (a long way from the previous gen).
If GM chose not to put the ZR1 wing on the ZL1 1LE, they had a good reason.
Current: 2019 ZL1 1LE A10
Mods: MPS4s Tires | Borla Atak | CF Steering Wheel
Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500
angryBits is offline   Reply With Quote
Old 02-03-2019, 09:08 AM   #18
WEAPON-X
WEAPON-X's Avatar
Have you ever seen Corvette and Camaro "share" the same wing? No... Their aero is designed around the car entirely by two completely different design teams and engineering teams.
Old 02-03-2019, 02:27 PM   #19
angryBits
angryBits's Avatar
Drives: ZL1 1LE A10
You make my point. If the wings were designed around the car by teams focused on that car, why would you think slapping a ZR1 wing (designed for a Corvette) on a Camaro would be better than a 1LE wing designed for a 1LE?
And to be honest, I've never seen a wing on a Camaro or a Corvette from the factory until now.
Old 02-11-2019, 11:12 PM   #20
Tabloma
Tabloma's Avatar
Drives: Red ZL1
I would like to have one for my A10 zl1👍
Tabloma is offline   Reply With Quote
Old 01-23-2022, 06:40 AM   #21
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
So what happened to this great looking wing?
Old 01-23-2022, 07:23 AM   #22
Number 3
Hail to the King baby!
Number 3's Avatar
First, without using CFD to at least provide some data, it’s tough to just throw numbers around like this based on Corvette. You’d be surprised at the little things that can impact aerodynamics. As pointed out, the base aero of the cars body and shape has so much impact on how the air will hit that wing and what it can actually do. Speaking from experience here.
Second any wing that provides more down force also provides less FE.
Third, OP I appreciate the effort here. A ton of work. But the wing is overpowering the appearance of the car. 7” wider is simply too big for the appearance, just JMO and that’s something others might appreciate. Good luck.
Old 01-23-2022, 10:27 AM   #23
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
What about this style wing for the Camaro!? I think the new C8 Z06 is exotic looking + functionality. I’d love to see how this (style) would look on our cars
https://cdcssl.ibsrv.net/cimg/www.ca...002-644602.jpg
SHE'Z 18 is offline   Reply With Quote
Old 01-24-2022, 05:27 PM   #24
dfxrte
Drives: 22 ZL1 M6
this would look horrendous on the zl1
22 m6 zl1. cammed, headers, etc
https://ibb.co/qpWHXZM][img]https://i.ibb.co/NKm0Q46/zl1.jpg
dfxrte is offline   Reply With Quote
Old 01-24-2022, 05:31 PM   #25
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
haha might as well get this wing from ebay
https://www.ebay.com/itm/164922135494
Old 01-24-2022, 05:39 PM   #26
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
OMG, that wing is hideous...
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 01-24-2022, 08:21 PM   #27
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
OMG!!! Hell No!!!
Old 01-24-2022, 08:31 PM   #28
PROMETHEUS
PROMETHEUS's Avatar
Old Thread.....
spoiler, wing, zl1, zl1 1le, zr1
