Old 01-09-2019, 08:55 PM   #15
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
probably your tune. a little is normal when cold. 1100rpm at cold start up is normal.
Old 01-09-2019, 09:20 PM   #16
dragoo
Drives: 2017 CAMARO 2SS
Originally Posted by JCunningham View Post
ya they can crack even if you dont think you hit them that hard. I always go the long rout when doing stuff ill take stuff apart just to make it as easy as possible. like removing plug 8 ill remove the reservoir and to make it easy.
Yeah I definitely learned my lesson.
dragoo is offline   Reply With Quote
Old 01-09-2019, 09:22 PM   #17
sav03cobra
SS Copbait R.I.
Think it could be timing related in the tune? Jannetty Racing is my tuner.
sav03cobra is offline   Reply With Quote
Old 01-09-2019, 09:23 PM   #18
dragoo
Originally Posted by sav03cobra View Post
So what if you don't have a cracked plug?
I have a M6 SS with CAI, Long Tubes, Ported IM, Ported TB and its 85* here. When I first start the car...its idle hangs around 1100, if I try to drive it before the motor warms up it bucks and surges for the first 30 seconds.
But if I let it warm up...its good to go.
Any ideas on that?
Do you have a tune? If you do I’d let your tuner fix that. I would also check and see if any spark plug boots are disconnected or not on tight. Another thing id do is check and see if the headers burned any wires because it gets hot as shit under the hood with headers especially when it’s 85 outside.
Old 01-10-2019, 12:05 AM   #19
sav03cobra
SS Copbait R.I.
Jannetty Racing Tuned my car via email data logs, I used SCT Tuner to import.
I changed out all wires with MSD wires and shielding boots, everything is tight from what I can gather. I did go one step colder on plugs, NGK (6509) LTR6IX-11 Iridium IX.
Old 01-10-2019, 03:09 PM   #20
dragoo
That might be why. Try stock ones! Some dudes had issues with those.
Old 01-10-2019, 04:39 PM   #21
sav03cobra
SS Copbait R.I.
Stock wires or stock plug range?
Old 01-10-2019, 10:46 PM   #22
sav03cobra
SS Copbait R.I.
Going to order some AC Delco 41-114 Stock plugs, it'll take about 10 days to get them.
Old 01-10-2019, 10:56 PM   #23
JCunningham
Drives: 2017 2SS M6
should be in stock at any parts store
Old 01-11-2019, 06:26 AM   #24
sav03cobra
SS Copbait R.I.
Yes, but since I live in Guam they charge a small fee of your arm, leg, and first born. Like no joke my Napa here wants $15 per plug....yes $15 per plug. I can order a set of 8 off amazon or eBay from an authorized detailer for $40.
Old 01-11-2019, 06:27 AM   #25
JCunningham
Drives: 2017 2SS M6
wow well if you don't already know do not check there gap. they are pre gapped and if you touch the electrode you will wipe off the iridum just put the in at 11ftlbs torque
Old 01-11-2019, 08:21 AM   #26
dragoo
Old 01-11-2019, 09:34 PM   #27
sav03cobra
SS Copbait R.I.
Copy that, thanks for the tips. I’ll post when I get everything swapped in.
Old 01-26-2019, 03:14 AM   #28
sav03cobra
SS Copbait R.I.
Got the new Stock Acdelco 41-114 plugs back in the car. I don’t know if it’s a placebo or not but the car felt stronger, rev match seems better, car warm up took a little less too.
I’ll post an update in a few days after driving. Hopefully this was it.
