Old 12-29-2018, 11:35 AM   #15
parish8
Drives: 17 SS a8
Thanks! I know one shop was able to net another 60whp over the LT4 on a stock fuel lobe. So perhaps it's advantages only show when not using a bigger fuel lobe cam being the LT4 can potentially handle a bigger fuel lobe which negates any advantages the LPE pump had? It's really hard to judge when LPE rates the gen 2 compatible with 7.85mm fuel lobe and the rest of the industry rates the fuel lobe in percentage.
that might be the whole issue. if you compare a gen 1 pump and limit it to a stock fuel pump lobe vs a lt4 pump with a 32% lobe the lt4 pump wins out and cost $700 less if you figure the fuel pump lobe option cost nothing.
or maybe that's not it and they did a gen 2 with a lobe and didn't see the expected results... who knows. port inject it and be done.
Old 12-29-2018, 11:36 AM   #16
laynlo15
Drives: 2022 Lt1 A10
So mine is a 35% fuel lobe, shizzys is a 38% fuel lobe and then there are 32%. Someone explain to me the advantage of a 35 or 38% over the 32%. Obviously this is my first experience with the fuel lobes and the lt4 hpfp which I have now. I had the gen 1 Lingenfelter big bore pump on the stock cam and didn't have to worry about this shit.
Old 12-29-2018, 11:40 AM   #17
ShizzySupra
Drives: 16' Camaro 2SS
Current cam is 32% my new cam will be 38%.
I am not going port injection. Just an off the shelf baby 2.3
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R
9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp)
ShizzySupra is offline   Reply With Quote
Old 12-29-2018, 11:51 AM   #18
parish8
Drives: 17 SS a8
pretty sure the different % is just a % of stroke over the stock lt1 stroke. at first I think they were little cautious about pushing the stroke too much over stock. seems no one is having issues so they are now going even higher.
Old 12-29-2018, 11:57 AM   #19
parish8
Drives: 17 SS a8
have you looked at a compressor map for that little guy?
Old 12-31-2018, 04:25 PM   #20
Sixgunsled
Sixgunsled's Avatar
Drives: 2017 camaro SS 1LE
I should be in the 8's as long as I can get any bugs worked out with no set backs. just finished building the motor, already have a built TH400, weapon x port injection system, big single turbo 88/96mm. Other than the back seats out i'll be full weight. probably weigh more seeing as how i'll be adding a cage.
2017 1000+hp Camaro SS
88/96 single turbo
manual to TH400 swap
15" conversion
Port injection
22K+ followers on Instagram @Sixgunsled
6.4K subscribers YouTube: Sixgunsled
Sixgunsled is offline   Reply With Quote
Old 12-31-2018, 06:37 PM   #21
laynlo15
Another turbo car, good to see a few running turbos, nothing like a spooling big turbo launch. Good luck
Old 12-31-2018, 06:53 PM   #22
Sixgunsled
Sixgunsled's Avatar
yeah thanks man i appreciate it. I've always wanted to try a turbo build so figured I'd go for it.
88/96 single turbo
15" conversion
Port injection
Old 12-31-2018, 07:26 PM   #23
18ss376
Drives: Camaro
You will never make a drag strip pass with a stock chassis. NHRA rule book will tell you what certified chassis to build to run the e.t. & speed for your car. Also some of your parts will need to be SFI rated.
18ss376 is offline   Reply With Quote
Old 12-31-2018, 07:36 PM   #24
parish8
Drives: 17 SS a8
I just read your build thread, no mention of a turbo. Have you started the fab work? Any pics?
Old 12-31-2018, 09:13 PM   #25
Sixgunsled
Sixgunsled's Avatar
In the very last post I talked about how I changed the build from my original plan of an F1A-94 procharger to a big single turbo. The motor and trans will be going in soon (probably this weekend) then I have to take it to have the custom turbo manifolds and crossover pipe made. If you want to follow all the build progress you can go back and see everything I have done on my youtube channel.
Also if you want to find out some info on the BMR motor mounts I talk about them and weigh them vs. the stock motor mounts ect. in the video
https://youtu.be/HR_q4iYdBME
88/96 single turbo
15" conversion
Port injection
Old 01-01-2019, 06:34 AM   #26
laynlo15
They are lighter, I don't remember the exact amount when I switched over but seems like 8-10 lighter total.
Old 01-01-2019, 06:52 AM   #27
laynlo15
Guess I was wrong on my weights, put those on a few months back. Great video.
