#15 | |
![]() ![]() ![]() Drives: 2016 Camaro SS Join Date: Sep 2018
With that being said I have the 2 inch TSP headers and they fit perfectly fine and I was able to get a Rotofab, E85 kit and tuning with the money I saved. |
#16 |
I'm on the 1 and 7/8 camp, the fitment, heat, and spark plug wire burning issues. I still have the OEM wires, can't say that on ANY 2". I did cook my starter so heat wrap of both the starter and two header tubes is a must no matter the header.. even OEM bone stock have starter cooking issues in Texas.
Drivability with M6 1 and 7/8 with cats is almost OEM. I think M6 with 2" and no cats will really have issues being a DD, (no low end torque as in zero).
#17 |
![]() Drives: 2010 camaro RS,2017 camaro 1Le Join Date: Mar 2016
You already got yours? I ordered mine too and they haven’t shipped yet
2017 camaro 1le
ROTO fab, Ported MSD, Ported 95mm tb, 2in TSP catless longtubes, flowmaster x-pipe, flowmaster American thunder npp, flex fuel, |
#18 | |
![]() Drives: Camaro Join Date: Sep 2018
I have been dynoing engines since 1987, the avg. loss is 15h.p. I have a lot of dyno sheets that prove this on different CI of SBC engines. Feel free to stop by & I'll put a LT1 on the dyno & prove that 2" primaries LOSE h.p. over 1-7/8" |
#19 |
there have been dynos out, as a surprise there does not seem much loss for the 2" header on the low end, not much gain on the top end. Of course this is WOT. For 99.99% of the people I think the 1 and 7/8 will be enough. Only on max build NA or FI above 700 WHP could I see the 2" with a no cat 3" exhaust system. Below that it is bench racing and matters little IMO, given this the 1 and 7/8 just has less draw backs. For an M6 I recommend only a 1 and 7/8 with cats for all builds period.
#20 |
I also use software called "PipeMax" to design headers it is very accurate.
http://maxracesoftware.com/PipeMaxPro400.htm |
#21 | ||
http://www.superchevy.com/how-to/eng...t-performance/ Also Joe at CPR recommends 2 inch headers on the new LT motors, said the 2 inch headers made more hp and tq across the rpm band. Quote:
Here back to back testing it says the 1 7/8 was better down low but the 2 inch did make more at 6000+ so the 2 inch still made more power. https://www.camaro6.com/forums/showthread.php?t=472259 Here 2 basically identical cars were tested and the 2 inch headers made more also. https://www.facebook.com/prayperform...type=3&theater |
#22 |
There have been more than a few dyno between 2" and 1 7/8" we're beating a dead horse. My issue is with fitment vs any small gain, and yes actual drivability, which favors the 1 and 7/8. I'd have to see 20 WHP gain by going to 2" due to the fitment problems and that ain't going to happen at my 709 WHP target, but assume 1000 WHP builds would see something like that.
IMO 99% of the people will be happy with 1 and 7/8. but would agree there is a few HP on the top end FBO with 2" and probably more max DD effort NA, max DD effort FI. Depending on how you define DD, I'm sure we all have 1000 WHP DD right.
#23 | ||
#24 |
Don't know why it quoted all of my post.
#25 |
This is not as good as PipeMax but it's free.
http://www.wallaceracing.com/header_length.php Also: https://www.yellowbullet.com/forum/f...splay.php?f=14 There are professional engine builders on this website & they know exactly what will work. |
#26 |
Just ran the numbers on my PipeMax software it says 1.71" primary max...LOL
#27 |
Real world results > software results. I'll stick with 2 inch headers.
#28 |
I do my homework before I listen to anyone.
The dyno & software are just tuning tools. Real world results = a time slip form the drag strip! |
