Old 11-22-2018, 07:11 AM   #15
JonD
JonD's Avatar
Drives: 2018 SS 1LE
LOL, these threads.
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune
https://instagram.com/corn_sauced?ut...d=o0ako89uurwl
JonD is offline   Reply With Quote
Old 11-22-2018, 09:29 AM   #16
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Worth the watch....
Skip to 13:00 to see info directly about the catch can, but the whole video is worth it.
'18 1SS 1LE Black, PDR
Old 11-22-2018, 10:12 AM   #17
cmeJATT
cmeJATT's Avatar
Drives: CAMARO
I think most people will say to add catch can. I think crowd favorite is Mishimoto
cmeJATT is offline   Reply With Quote
Old 11-25-2018, 08:05 AM   #18
ecko04
Drives: Too many to list
Are catch cans necessary? No. To say they’re necessary would be an admission of a design fault.
Can catch cans catch some junk that would otherwise make its way to the valves and intake track? Do they catch all the junk? Yes. No.
Do catch cans work? Yes, but to the degree they work is a matter of who engineered the can and your definition of “work”, all are not created equal in this instance.
Do catch cans harm the engine? No.
Are they worth the money? That’s a personal decision.
In cooler weather check the catch can more often due to condensation that may build up as the temperature drops.
Sent from my iPhone using Tapatalk Pro
ecko04 is offline   Reply With Quote
Old 11-25-2018, 08:24 AM   #19
Boost Creep
Drives: '18 1SS 1LE
Here's a test I did +6 years ago using an Elite Engineering catch can.
I put a clear plastic fuel filter in the line after the catch can and before the intake to try to see if anything is getting past the catch can.
https://www.ls1gto.com/forums/showthread.php?t=423689
The catch can would collect a full ounce of oil/crap between oil changes (3000 miles) while letting maybe a drop of oil vapor get past.
Old 11-27-2018, 11:50 AM   #20
sal11585
Drives: 2017 Camaro SS 2ss Nightfall Gray
It's not expensive, and it does keep a lot of oil out the manifold, and it's super easy to install. I installed one when I did my CAI
ACS front spoiler, rear spoiler, side skirts and rock guards (gloss black). Real carbon fiber dash insert, real carbon fiber gear bezel, GM dark tail lights, Gm black badges(Emblems and ss)
Powder-coated gloss black factory 5 spoke split wheels
Roto fab Biggulp CAI
Full paint correction with cquartz finest ceramic coating
Whipple 2.9
ARH Long tube headers with High flow cats
1le sway bars F&R
BMR Upper and lower trailing arms
Hurst short throw shifter
sal11585 is offline   Reply With Quote
