Old 12-26-2018, 02:35 PM   #15
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Originally Posted by irobles3680 View Post
Update: driving to work not under heavy acceleration I get cel for P0299 along with reduced engine power on dash(definitely felt lack of boost). Checked all wires were connected and bolts and they were good, will remove recirculation valve to see if it clears code.
Sorry to hear you're having this issue. It has happened a couple times with 2 people so far, but is curable. We don't know exactly why it happens, but generally remove, and reinstall fixes it.
I will send you an email.
Old 12-26-2018, 11:23 PM   #16
irobles3680
Drives: 2017 2.0 Camaro LT
Update: removed valve- piston was stuck in the pressed position. Removed valve from stock bypass valve and lubed using gun oil to all o rings(stock and jacfab o rings)and pushed the piston a lot of times to lube that as well, placed back on and got rid of cel, no limp mode, went wot a lot of times and drove for few miles, everything feeling good now!
Definitely recommend lubing it a bit more once you get it to avoid piston staying in pressed position
irobles3680 is offline   Reply With Quote
Old 12-27-2018, 01:38 AM   #17
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
What did you use to grease it up?
Old 12-27-2018, 03:22 AM   #18
irobles3680
Jason recommended a thin oil like gun oil, atf or sewing machine oil. I used gun oil from my glock, and seems to work well. Will keep driving and post if anything else comes up
Old 12-27-2018, 12:09 PM   #19
Jason@JacFab
Glad you got it working...
To anyone else that has been following along, I know that some of your have bought these and are waiting for spring time to put them on. It's probably a good idea to lube them up before installing since they will have been sitting for a while.
Old 01-06-2019, 05:30 PM   #20
AdamJT11
Drives: 2015 Cadillac ATS 2.0 Premium 6MT
Is this something that should periodically be done after install as well?
AdamJT11 is offline   Reply With Quote
Old 01-07-2019, 09:26 AM   #21
dekes1
Drives: Camaro like
Jason, any thoughts on machining the piston a few thou smaller in diameter to potentially reduce the likelihood of having to oil it? Or what about cutting in a small taper?
dekes1 is offline   Reply With Quote
Old 01-07-2019, 01:45 PM   #22
Jason@JacFab
I don't think so. There generally seems to be enough oil mist, etc, in the intake tract to keep it lubricated once its on... I pulled one off here not long ago, i had been running it for about a month, and there was more lube on it than when I had put it on. If you do have to pull it off to oil it, it won't be very often.
It's not actually the piston itself that really needs the lube, but the oring on the piston inside the bore.
As the part isn't designed to be taken apart by the end user, you when you lube it you apply the lube onto the side of the piston on the top edge of the bore, let some lube slide into the bore, and work the piston in and out a few times to get the lube onto the oring.
Old 02-14-2019, 08:13 AM   #23
jbmorris1987
Drives: 2017 2.0 summit white
Jacfab recirculator
Any estimated date for the “no tune” version?
jbmorris1987 is offline   Reply With Quote
Old 02-18-2019, 10:54 AM   #24
jbmorris1987
No tune version
Any date for the no tune version?
Old 02-18-2019, 03:39 PM   #25
6th_gen_gino
Drives: 2016 camaro 2.0t gray
Are u in it purely for the noise since you don't want a tune?
6th_gen_gino is offline   Reply With Quote
Old 02-18-2019, 05:26 PM   #26
Jason@JacFab
We don't have any kind of hard estimated date just yet. I have a current prototype on my car right now, and so far no check engine light. Need to do more driving, logging, etc still.
Old 02-26-2019, 06:46 AM   #27
Keandre8
Keandre8's Avatar
Drives: Summit White 2018 Camaro LT
Any ETA on when you will have them back in stock?
Keandre8 is offline   Reply With Quote
Old 02-26-2019, 03:06 PM   #28
Jason@JacFab
I actually have 2 (of the tune version) in stock right now. if you tried to order one and saw that they were sold out on the website, the inventory number was off. I have fixed it.
That said, another batch it in the works, not exactly sure when they will be ready. We are currently waiting on shipping materials (the nice foam box inserts), and one replacement tool for the lathe to be able to finish making the parts, and get them boxed up.
