Old 10-04-2018, 12:21 PM   #15
1LE Red Dragon
Train Driver
Drives: 2018 Summit White ZL1 1LE
you should be able to at least match the opening to of the snout or as they call it gasket matching to run the larger tb.. other porting would be more difficult.
The question is, can you successfully open up the snout opening to 95mm while the blower/snout is still on the car? You are going to be removing about 4mm of material around the opening to enlarge by 8mm in diameter.
I have seen this done in the past by people. They usually stuff rags inside the blower inlet then grind away. Once completed, you vacuum up the shavings you can see, and then pull the rags out to get any remaining shavings. I dont know what the material of casting is on the blower snout. Is it aluminum or iron?
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / /
1LE Red Dragon is offline   Reply With Quote
Old 10-04-2018, 12:39 PM   #16
IneedAZ
IneedAZ's Avatar
On the ZL1 drag car video from Sema they mentioned they installed a larger TB but made no mention of having to modify the opening. I thought they went with the 103mm TB, but not positive.
Old 10-04-2018, 01:39 PM   #17
laynlo15
Drives: 2022 Lt1 A10
Yes matching would be much easier and probably take care of it.
Old 10-04-2018, 03:09 PM   #18
Alain
Alain's Avatar
Taking the supercharger off to get it ported puts this throttle body mod on a different level of modding.
I’m sure there is still some benefit to be had even when the supercharger snout is left stock. But I’m certain there are gains being left on the table by doing that.
2018 ZL1 1LE/Red hot
Old 10-04-2018, 04:13 PM   #19
laynlo15
I'm only talking about port matching the snout to match the 95mm TB.
Old 10-05-2018, 08:21 AM   #20
Fraxum
Fraxum's Avatar
This! ^
Since the blower has to come off might as well port the whole blower.
So a Rotofab+95MM TB + Ported blower + Snout = Noticeable power jump.
Old 10-05-2018, 08:42 AM   #21
1LE Red Dragon
Train Driver
Originally Posted by Fraxum View Post
This! ^
From what I've and others have seen on logs of fuel trims, I would not suggest running the Rotofab without a MAF scale adjustment. Yes it will run and be safe and won't throw CEL, but it way over reports air mass. That may be why it loses torque. Once the MAF is rescaled it's a very good gain on a blower car.
Yes. You should get a noticable power jump with those mods. With over reporting MAF you may run into torque limits without a tune and get throttle closure though. My $.02
2018 Camaro ZL1LE
Old 10-05-2018, 09:29 AM   #22
wlsmoku
Drives: 2018 ZL1 A10
you hit the nail on the head and is the exact problem I ran into with just a vengeance CAI....couldnt tell much on the street, but at the track my 60ft times were HORRIBLE! I put the factory intake back on until I am ready to tune it and all is back to normal. you could literally feel the tq management ruining the launch
wlsmoku is offline   Reply With Quote
Old 10-05-2018, 03:25 PM   #23
Fraxum
Fraxum's Avatar
This is news to me. I was thinking I could just run the RF and be okay. Is that not so? Otherwise I had hoped I would not need a tune for 95MM + Ported SC. But I figured I was dreaming. It's just once you tune you can't go back And I would feel guilty passing on a previously tuned car as stock. So I have the RF, I might as well try it.
Old 10-05-2018, 09:47 PM   #24
WEAPON-X
WEAPON-X's Avatar
Drives: ZL1 ATS-V CTS-V C7Z Range Sport SC
we have these complete kits including optional porting for sale
https://weaponxmotorsports.com/produ...=8667505262683
WEAPON-X is offline   Reply With Quote
Old 10-05-2018, 10:58 PM   #25
1LE Red Dragon
Train Driver
Yes. You can run it with no problems. However the stock MAF calibration is not perfect for the Rotofab. The LTFT will be negative a good bit. This is ok for safety standpoint but not ideal for power and torque. To get the most from it, the MAF needs calibrated. From what it seems a ported blower and snout on a stock tune is okay with the stock air box. The 95mm I would think would be as well if added. The Rotofab adds another variable and logs would need to be done.
2018 Camaro ZL1LE
Old 10-06-2018, 09:04 AM   #26
Fraxum
Fraxum's Avatar
I see, and the stock intake does already flow pretty well. As you said in any case I need to start logging after any changes.
What is the best way to learn how to read a log? I know only enough to get myself into trouble.
But all of a sudden there is a new player:
https://www.camaro6.com/forums/showthread.php?t=540092
Now this is really interesting. Can Chevy void our warranties if we bolt on Chevy parts?
Old 10-06-2018, 11:11 AM   #27
Mcmillion
Drives: 2018 ZL1 1998 SS 1992 Typhoon
LoL, I agree best way to run the 95MM is to bolt on the blower it was made for
Mcmillion is offline   Reply With Quote
Old 10-08-2018, 12:51 PM   #28
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
should work fine just will lose the o ring option most likely.. may have to seal with silicone or make a paper gasket..
get some dial calipers and measure where it goes to see if there is room for porting or make a template of a circle on paper with the new mm circumference place over the snout opening mark it and see how much room you can port, if ya do scribe lines then grind away..
I did all this back in 97 with my LT4 intake and TB. the gaskets on the original LT stuff especially LT4 were bigger than the Aluminum openings on the intake.. they laid over the heads pretty well after CNC porting from lingenfelter but the intake was terrible really had to gasket match the intake and tb ports.
