Old 09-09-2018, 09:07 AM   #15
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Originally Posted by headgamez View Post
Ah gotcha!! Then install the barbed fitting, which I am assuming needs to be modified because in some instances it was hitting the water pump?
The brass nipple coming into contact with the top of the water pump was supposed to have been corrected by Elite. If I understand correctly they reworked their diverter design to have the nipple seat further into the diverter. I'm curious to see if you have any issues
Old 09-09-2018, 02:43 PM   #16
SSallday
SSallday's Avatar
Drives: ‘18 ZL1 / ‘22 ZLE
Good news: I received my catch can
Bad new: I believe they sent me the wrong one. The online receipt shows that I purchased the E2X Can (E2X-A1DVP20) but the receipt in the box has LT1 V8 (E2X-A1DVP17). I also didn't receive the brass nipple. Now I have to wait again.....
SSallday is offline   Reply With Quote
Old 09-09-2018, 07:06 PM   #17
zfuzz
zfuzz's Avatar
Drives: 69 Z28 / 12 ZL1
Great post and info guys! Any tips on lifting the super charger? Does it take a pry bar at certain points to break it free or does it simply lift up with ease?
zfuzz is offline   Reply With Quote
Old 09-09-2018, 10:10 PM   #18
headgamez
Drives: 2018 Camaro ZL1
I wonder if I can place a right angle quick disconnect on the diverter instead of the barb? I will have to check it out once I get mine.
headgamez is offline   Reply With Quote
Old 09-10-2018, 03:33 AM   #19
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Low torque spec, it's an easy lift.
2018 ZL1 1LE sw/PDR
Old 09-10-2018, 06:36 AM   #20
Biscuit.fr
Drives: Red hot ZL1 A10 2017
I lift mine alone by hands
Easy
The gold part is screwed inside the silver with Teflon
I think you may work another connection like quick disconnect if you have one...
Still have to lift to switch PCV....
Biscuit.fr is offline   Reply With Quote
Old 09-10-2018, 07:51 AM   #21
zfuzz
zfuzz's Avatar
Easy
Thank you guys for the reply
Old 09-27-2018, 12:13 PM   #22
SSallday
SSallday's Avatar
How did you guys connect the hose to the intake and connector? I understand you are suppose to drill a hole into the stock intake for the plastic elbow but I have a roto-fab intake. Is it the same process?
Old 09-27-2018, 12:22 PM   #23
Biscuit.fr
You suppose right
Drill a hole into the intake (rotofab same)
Old 09-27-2018, 09:03 PM   #24
kwav8r
Flyin NOE
Someone on this forum found a T-fitting that would allow you to replace the L-shaped fitting on the RF. Not sure what size but if you find the post I believe it’s in the thread
Old 09-27-2018, 09:48 PM   #25
SSallday
SSallday's Avatar
I watched a video of someone who put a T-fitting and that's exactly what I'm looking for. I really don't feel like drilling a hole into the intake
Old 09-27-2018, 10:58 PM   #26
waterman
waterman's Avatar
https://www.amazon.com/Eldon-James-T...70_&dpSrc=srch
No additional drilling necessary. They work like a charm. As inexpensive as they are , you would think that the CC manufacturers would include them in their kit as opposed to instructing you to drill into your CF or composite intake tube.
There are 10 of them, but for $11, you can share them with your friends.
2018 ZL1 1LE sw/PDR
Old 09-28-2018, 12:24 AM   #27
SSallday
SSallday's Avatar
Thanks!! Yeah, I wasn't expecting to drill into my new intake to install a catch can. I agree that they should consider using the tees in their kits
Old 09-28-2018, 12:36 AM   #28
waterman
waterman's Avatar
2018 ZL1 1LE sw/PDR
