Old 08-27-2018, 08:10 AM   #15
pbsinternet1le
pbsinternet1le's Avatar
Drives: 2017 1le current /2015 2ss 1le sold
Ported throttle body helps.
2017 1LE Hyper Blue
pbsinternet1le is offline   Reply With Quote
Old 08-27-2018, 10:29 AM   #16
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Can't you just set the mode to track and set the steering to tour from the screen?
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 08-27-2018, 10:49 AM   #17
MATTY-1LE
MATTY-1LE's Avatar
Drives: 2018 Camaro SS 1LE
this is an easy fix, manually input all your settings to where you like them, leave the car in track mode via the button next to the shifter
note: when you switch the mode via the button next to the shifter, all your manual driving customizations stay the same, the only thing changing is the pedal throttle per what mode you choose, i have played with this thing time and again
Current:
2020 V6 A10 - looooving the regular unleaded, over 20mpg, and excellent daily driver manners!!!!!
Past:
2018 1SS 1LE - stock
2008 C6 - heads/cam/boltons
2005 GTO - cam/boltons
MATTY-1LE is offline   Reply With Quote
Old 08-27-2018, 11:09 AM   #18
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Exactly. That’s what I’ve done from day one. The touch screen settings are overrides.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 08-27-2018, 11:49 AM   #19
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2020 2SS
Track throttle is the worst.
Bad Anvil Garage is offline   Reply With Quote
Old 08-27-2018, 12:29 PM   #20
MATTY-1LE
MATTY-1LE's Avatar
Originally Posted by protovack View Post
Ok, so it seems like I'll need to get a tune
read my response, this is an easy fix, no tune or anything needed,. surprised most people havent realized that customizing the settings overrides the mode button, except for the pedal throttle.
Current:
Past:
Old 08-27-2018, 01:32 PM   #21
VinnAY
Drives: 18 1SS/1LE
on the street which as as far as Ive gone I dont like it at all.
I find that running the options thru the menu and selecting from default is what I prefer, all around/day-to-day.
Steering: tour
Exhaust: track
Suspension: sport
Main setting: sport
Old 08-27-2018, 02:44 PM   #22
Dave-ROR
Drives: A few
You can't leave the car in track mode. It switches to Tour on next startup if you turn it off while in Track mode.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback
Too many cars.. never.
Dave-ROR is offline   Reply With Quote
Old 08-27-2018, 02:47 PM   #23
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Sport will restart in sport.
Every other mode will restart in tour, no matter where you have it set when you turn it off.
Old 08-27-2018, 03:05 PM   #24
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Sorry if this is a repeat but, I needed a quick clarification on something.
I really like the driving dynamics of track mode, however I prefer to keep the steering on "tour" mode for daily driving.
My ideal settings are:
Steering: tour
Sound: track
Suspension: track
When I turn off my car, it resets to "tour" mode
But the individual settings stay at their previous values.
However, there is not an individual setting for "throttle response"
And that's one of the main things I prefer about track mode, is the linear throttle response.
Is there ANY way to get the throttle response to stay in track mode without having to manually scroll through and select track mode every time I start my car?
Throttle response is the only feature that is always directly tied to the mode button. It is possible to override all the other features though. So you can override to Tour steering, Track Exhaust, Track suspension and then essentially the only thing your mode button will change is the throttle response.
Honestly if I was you, I would just set steering to Tour and set exhaust to Track. By doing that you can still switch your suspension with the mode button for bumpy roads. Your never more than 2 clicks of the mode button to get to any desired setting.
Old 08-27-2018, 08:53 PM   #25
glenB
Drives: Chevrolet Camaro SS
Try a ported TB. It doesn't really add HP but it will increase throttle tip in.
I would be leery of missing with the throttle tables, even HP suggests leaving them alone unless you or your tuner is well versed in it.
glenB is offline   Reply With Quote
Old 08-27-2018, 08:56 PM   #26
AD17SS1LE
AD17SS1LE's Avatar
Drives: 2017 Camaro SS 1LE
Maybe with one of these:
https://www.vitesse-motorsports.com/...my-vehicle.htm
I had this on my car, it caused it to go into limp mode 3 times and throw codes. I took it off. It did work for variable throttle response well but the limp mode and codes I can't live with.
2017 Camaro SS 1LE
Pray ported TB/IM
TSP 1 7/8 Long tube headers w catted con pipes
Taylor plug wires
Mishimoto oil cooler
Elite X2 catch can
AD17SS1LE is offline   Reply With Quote
