#15 | |
![]() Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
The EMP is the only pump we have in the system at this point, with 1" lines it should have adequate flow to the cooler, if not we'll add more pumps. |
#16 |
Well said Mike. Thanks for the input on all those numbers most of us don't understand.
#17 | |
#18 | |
4L80 is basically a TH400 with overdrive, so once built, they will handle anything you can throw at them. The ATI T400 MAX DUTY we're using here is rated for 1800HP and up. Unfortunately the Camaro didn't get finished last week so no testing yet. Hopefully in the next couple weeks. |
#19 |
Finally after wayyy to long - it's finally running again!
https://youtu.be/Qv_XO07DiC0 Getting a couple of the ECUs to accept the fact that there wasn't a transmission ECU anymore took a bit more time than expected, but our calibration group got it all worked out and the car works as stock with retaining the push-button start/stop. Unfortunately wont get a chance to hit the track before SEMA, but we have a couple events on the west coast this winter to start dialing it in with the new parts. If you happen to be going to the SEMA show and would like to see the car in person, you'll find it at the EATON booth in the Main Hall. |
#20 |
I can't wait to see it again. It will be my first time at SEMA, should be pretty special and long days but worth every minute of it.
