#15 |
Nice...I am out South West over by Homestead.
#16 |
![]() Drives: 2018 1LE SS "Silver Bullet" Join Date: Jun 2016
Silver Bullet 1LE SS
#17 |
![]() Drives: 2017 2SS Fifty Join Date: Nov 2016
Did you ever solve this?
#18 |
![]() Drives: 2016 Chevy Camaro 2SS Join Date: Aug 2012
Check the plug once more. I had a similar issue and i had to make sure they were all aligned with the other pins. I will compare your tune to my mines if you haven't already found the solution.
#19 |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
When every they default to 40% there is a communication issue between the sensor and the computer.
Ted. |
#20 |
![]() Drives: 2016 2ss Join Date: Aug 2015
No i never solved this. I've re-seated the pin a million times. I have a pump near me with 100 octane unleaded and im just gona tune off of that.
#21 |
Have you checked the wiring harness to make sure there is continuity and not a bad connection?
#22 |
#23 |
![]() Drives: C5 Z06 LS7 Join Date: Jun 2014
We can take a look at it for you @ decatur.
#24 |
Iroc-z
Drives: Camaro SS 2017 Join Date: Mar 2019
finally you resolved the problem? I have the same problem in my 2017, the signal is bad or no signal in the ecm, I checked everything and everything is good, the problem persist not have a signal in the ecm
#25 |
No, I never figured it out
#26 |
![]() Drives: Corvette Join Date: May 2016
I had the same problem and it was a bad sensor.
