#15 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Audi TT RS Join Date: Jan 2014
It's largely that section where you see in the picture, I believe. When I took my manifold apart to toss RTV all around it, the gasket going to my throttle body was all kinds of messed up. It was not seated correctly nor was that back corner really tightened down. I have since RTV'd the whole thing and used blue Loctite everywhere I could. The only issue I can see, is the brake booster line that goes in the back of the manifold. There's no way it's getting a proper seal and honestly, I don't know how to address that.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
#16 |
Drives: All GM Performance Join Date: Jul 2011
We have installed several of these intake manifolds. We haven't done one yet that had a vacuum leak. When you get all the bolts installed and then the manifold bolted down the gaps always close up for us. I do see them leaking oil out of the pcv connection (which I can't stand) But lucky for us, no vacuum leaks to speak of.
#17 |
![]() ![]() ![]() ![]() Drives: 1LE Join Date: Sep 2017
#18 | |
![]() Drives: 69 Camaro & 2017 SS Camaro Join Date: Jul 2018
This is off topic and random but have you tracked your car yet? I was reading your list of mods and was curious, I'm planning on running something close to your setup. |
#19 | |
![]() Drives: '17 SS/1LE/PDR Join Date: Feb 2017
https://www.corvetteforum.com/forums...-manifold.html
PRAY ported MSD/TB : ROTOFAB/dry : DSX flex fuel : HPA Stage 3 : ARH catted long system/oem NPP : RSR harness bar : RSD : FSO1 : MPS4S 305F/325R
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 SS Join Date: May 2013
We port around 3 a week and they get sent in, ones we order have came with missing bolts and gaskets as mentioned.
#21 |
![]() Drives: 2002 Camaro SS Join Date: Jun 2012
Wow, how does that slide past either QC or the guy packaging them. That is crazy to me. I'd be let go pretty quick from my job if I was sending out parts like that.
2017 1SS Hyper Blue M6
2001 Ford Lightning |
#22 |
