#15 | |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
Florida High Performance: H/C Whipple LME 377 900WHP
#16 |
![]() Drives: 2016 Camaro 1SS Join Date: Feb 2017
Quick update as i said screw it for now. Ill do this again in the spring when im not aggravated lol. Removed accesory belt and tensioner super easy. With motor in neutral, turned the motor manually and walked off old ac belt very easy. Breaking the old crank bolt loose was took a bit of ass. First tried 5th gear and found it to mushy as it allowed alot of backwards movement in the motor however with it in 4th (1:1) it was much better. Now the problems:
1. The autozone rental chrysler style 3 jaw puller will not work stock. The jaw size is fine however it comes with a shorter and longer rod. The longer rod is nowhere near long enough to even get the remover fully tought none the less actually pull anything. In addition, the bolt that threads through the jaw of the puller was slightly cross threaded so i advise to run the threads through by hand while your still in the auto store. Secondly the autozone rental long reach installer will require as far as i can see the removal of the fans. Not that i got that far but while im sitting here drinking i decided to take a look at it and it wont even angle correctly to get to the crank hole(at least with the oem pully still on but that tells me trying to angle it to get it out after seating the ati could be a pita. We are having the snowpocalypse here in st louis right now otherwise id walk to lowes to see if maybe they have a thin barstock solution i could maybe cut to size to use the puller succesfully. Anyways in short just providing some good lessons learned. Now ill go wrestle the ac belt back on and find the maf screw i dropped in the bay..and drink.
1. Phastek detachable front license plate bracket 2. Blacked out Bowties 3. Blacked out sidemarkers/third brakelight 4. Rotofab dry/no soundtube CAI 5. VMAX ported throttlebody 6. Kooks 1 7/8 Longtubes with Hi-Flow Cats 7. EFI Tuning Flex Fuel kit and tune 8. HP Tuners NGAUGE 9. Zeitronix ZT-2 Wideband(reads on NGAUGE) 10. Ported MSD intake manifold 11. CORSA XTREME axle back w/ dual quad black tips
12. Racestar Darkstars 17X9.5 with Mickey Thompson ET Street SS 305-45 17 Radials 13. Kicker 3-way door speakers. DYNOCOM mobile dyno trailer: 471hp/490TQ@97degrees ambient/ethanol percentage=80% |
#17 |
@Blackmamba_1LE
Just purchased this used of another member. Any recommendations or what to look for? It will also come with an ARP bolt are ARP bolts TTY also like the OEM ones?
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
auto or manual tranny? how did you keep the engine from turning over?
#19 |
![]() Drives: 2018 2ss 1le Join Date: Jan 2018
what are anyone's impressions after doing this mod?
does car feel smoother, faster? was it worth it?
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned |
#20 |
@Blackmamba_1LE
I will be installing mine tonight... Ill post pics and feedback later
#21 |
![]() ![]() ![]() Drives: 2016 Camaro SS Join Date: Sep 2018
#22 |
![]() Drives: 2016 2ss Join Date: Mar 2012
Do these install the same for autos and manuals?
#23 |
![]() Drives: 2001Camaro Z28 Join Date: May 2009
#24 | |
I think i just used a 3/8 drive extention shoved into the cank
#25 | |
![]() Drives: 2024 Toyota Camry XSE Join Date: Sep 2017
Larry, I'm glad I did it. Do I feel anything different? No. ATI claims that it adds a little (8-12 hp) to the WHP. I have read in the NHRA rule book that it is a requirement if you go 10.99 or quicker. Has a tech inspector ever said anything about it to me, no. Bottom line to me is just peace of mind that the harmonics of the rotating mass in the engine is protected, I'm playing by the rules, and, just maybe, this along with a lot of other little things I've done make the car a tenth faster.
2016 1SS - Bought: 8/2017 Sold: 12/2023
#26 |
I have one on mine...it came with my Whipple kit. Can not say if it adds anything. I am sure it's a better piece then the stock unit. Pretty sure I seen another thread a while back where it made 8-9whp gain.
#27 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
It smooths out the nvh from the engine into the cab. Car doesn’t go slower with it.
#28 |
![]() ![]() Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85 Join Date: Oct 2016
guys wouldn't it be easier to remove the bumper to install it?
Well............ At least you tried. lol
