#15 |
![]() Drives: 2017 Camaro SS 1LE Join Date: Sep 2017
Ive used ATE and didnt get any brake fade until my 5th track day with low pads. its relatively inexpensive and did well overall. I play on trying a different fluid to compare and contrast
#16 |
![]() Drives: 2017 Camaro SS 1LE Join Date: Apr 2017
I just ran at Yas Marina Circuit in Abu Dhabi after a switch to Motul 660. My first time out with stock fluid in cooler weather I had a mushy pedal pretty much after the first lap and I lost the pedal all together once.
The session on Monday night was 98* ambient at night with about 80% humidity. Basically it was miserable outside the car lol. The pedal remained firm and confident all night (3 hours open track). I ran into a little brake fade at the end of the big straight near the turn-in point. I was running about 133-135 mph into a hard 90* left but still had good pedal feel despite the fade. I was running about three or four fast laps and then cooled down a lap and would usually bring it in the pits. I want to say I got about 100 minutes of PDR footage. It typically takes me just under three minutes to run a lap when I am pushing it and just over three when I am not. The Motul 660 was cheaper than SRF and I couldn't get SRF shipped out here for some reason. I was quite pleased in the difference! |
#17 |
![]() ![]() ![]() ![]() Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
after talking to a few friends that have run road america a lot I decided to order ATE type 200.
#53 F Street
2025 FS National Champion 2025 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 |
#18 | |
![]() ![]() ![]() ![]() ![]() Drives: '17 ZL1 Join Date: Jul 2016
Right Rear Inner then Outer Left Front Inner then Outer Left Rear Inner then Outer Right Front Inner then Outer |
#19 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
The Motul 660 is the best fluid there is when it is fresh out of the bottle but you need to change it at a minimum of every 6 months if you track the car a lot because it absorbs more moisture and degrades. I recently switched to the Castrol SRF and now prefer that fluid, it is much, much more stable than the Motul and probably could be run for years without significant degrading of the fluid. I'm now a big SRF fan. All of them will be fine in the winter if they are fresh.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. ![]() |
#20 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Probably fussier than absolutely necessary, but I can't see it hurting anything to do a couple of brake pedal pumps the second time on the inner. Norm
'19 WRX 6M (the family sedan . . . seriously) |
