#15 | |
Tread Marks
Drives: 2016 Hyper Blue Camaro 2SS Join Date: Apr 2017
Sent from my Pixel 2 XL using Tapatalk |
#16 |
![]() Drives: 2017 2SS Summit White Camaro M6 Join Date: Mar 2012
I think the a/c should be capable of any temp you desire and not have such extensive fogging! Big fail on GM!!
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
I agree!!!
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
#18 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 SS 1LE Join Date: Dec 2015
I traced the shape of the air vent on some paper and then folded a bandanna to fit. Most of the “vent” is actually fake.
#19 | |
Tread Marks
#20 |
To cover the vent, I bought a srtip of "rubber wall cove base" from Home Depot.
Made a pattern from cardboard, traced the pattern onto the rubber sheet, cut it out, and slid it in place over the dash vent. No more fog. Being a pliable rubber, it stays in place but is easily removed as needed. Between the texture of the rubber base and if you make clean/straight cuts, it vanishes from sight both inside and outside the car. You have to look to see it, if you get my meaning. |
#21 | |
#22 | |
Thank you Al Oppenheiser!
As long as you use the rubber one, you’d be fine, althouh it might smell like a new tire inside your car for a while. But if you did get PVC by mistake and parked in the sun you’d really regret it after it melted and oozed down into your vent. |
#23 | |
#24 | |
Do you have any pics of it? Frustrated with mine Last edited by BigDaddy986; 08-27-2018 at 09:46 AM. Reason: More detailed question |
#25 |
![]() Drives: 2017 2SS Join Date: Jun 2014
Grabbed a quick pic at a stoplight. This is what I made with 3M DiNoc vinyl. It's sticky on one side, so it sticks down just fine. Lasted over a year in New Orleans heat.
![]() The pic was taken up by my mirror. It's not nearly as visible from the driver's seat. |
#26 | |
Overall shape and size: ![]() View from driver seat: ![]() View from outside the car looking from right/front toward left/rear ![]() Same pic as above with the cover highlighted because of the reflection off the windshield:
#27 |
Nice work!
#28 | |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
Works great!
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
| Tags |
| camaro, cover, defrost, vent |
